POV-Ray : Newsgroups : povray.newusers : POv code from movray Server Time
29 Sep 2024 14:07:40 EDT (-0400)
  POv code from movray (Message 1 to 10 of 17)
Subject: POv code from movray
Date: 21 Mar 2006 08:25:00
Message: <web.441ffde1b2a1aa63d9284750@news.povray.org>
Hello Everbody, first of all i thank those who helped me with my first
question, :) and sorry for posting the same question in multiple groups. i
now have a simple question.. is it possible to generate a pov-ray code(SDL
code) from a scene generated using movray? i would like to do this..
becuase i want to edit some features of my camera settings. would be
thankful to anybody who has a suggestion for me in this regard
Thnk you verymuch in advance
amar
Subject: Re: POv code from movray
Date: 21 Mar 2006 09:15:00
Message: <web.442009df9a014eb9b1b469160@news.povray.org>
> Cheers
> amar
Moray does this for you. If you look in your renter options (Alt + F9) in
POVSCREEN
Here you will find .POV, .INI and .INC files with the same name as your
Moray file.
A hint; open them in PovRay and save them in an other directory as Moray
will overwrite them if it is run again. You might have to add the path to
All the materials in your Moray scene are written to your myMorayScene.inc
and the rendering settings in the myMorayScene.ini. This is the file you
run in PovRay.
Date: 21 Mar 2006 09:22:02
Message: <44200c0a$1@news.povray.org>
news:web.441ffde1b2a1aa63d9284750@news.povray.org...
> Cheers
> amar
I presume you refer to Moray...
Moray outputs  SDL files to POV.
These files are in the folder set in render options (Alt+F9) "Directory for
POV files" is what you are looking for.
Say you saved your scene as "My-scene.mdl"
In the export directory, you can find:
"My_scene.pov" for the global_settings, cameras, lights, geometry...
"My_scene.inc" for the materials and textures
"My_scene.ini" for the render settings as image size, anti-aliasing
settings...
Sometimes extra include files for rotational or translational sweeps
exported as triangles.
Marc
Date: 21 Mar 2006 09:22:27
Message: <44200c23$1@news.povray.org>
> Cheers
> amar
I presume you are reffering to Moray :-)
Moray exports SDL to POV
You can see (and set) in which folder POV file are exported in the render
options tab(Alt+F9)
"Directory for POV files" is what you are looking for.
Say you saved your scene as "My_scene.mdl"
In that directory, you can find
"My_scene.pov" which contains global_settings, camera, light and geometry
"My_scene.inc" which contains the materials and textures
"My_scene.ini" which contains render settings as image height and width,
anti-aliasing etc..
sometimes some extra files but the mains are those 3.
If you want the opportunity to type SDL directly in Moray, you can try
InsertCode plugin
http://www.stmuc.com/moray/download/pub/moray/plugins/InsertCodeMFC%201001.zip
Marc
Date: 21 Mar 2006 09:27:30
Message: <44200d52@news.povray.org>
1.- Open the moray file in Moray.
2.- Render it using Moray (Povray will open to render the scene).
3.- Close Moray.
4.- In Povray go to File -> Open.
5.- The povray files (x.pov, x.inc and x.ini) are in
        Program Files\Moray for Windows 3.5\PovScene\
(where x is the name of the moray file you are using).
6.- Open them.
7.- You'll find the camera statement in the first lines of the x.pov file.
8.- Enjoy.
Tip. If you want to keep your changes, be careful not to render the Moray
file again from Moray, since the file will be overwritten. Save the files
(.pov,.inc and .ini) in another folder.
I'd be glad if it helps.
> Cheers
> amar
Bye
Txemi Jendrix.
Povray and CG: www.txemijendrix.com
Music: www.losmiercoles.net
Date: 21 Mar 2006 09:27:54
Message: <44200d6a@news.povray.org>
news:44200c23$1@news.povray.org...
oops just want to tell I got no Alzheimer yet, Outlook crashed and I was
sure my 1st post was not sent...
so I double posted
Marc
Date: 21 Mar 2006 09:37:19
Message: <44200f9f@news.povray.org>
news:44200d52@news.povray.org...
You can export the files without render them with the menu item
render/export  (Ctrl+F9)
I use that mostly to render the scene with Megapov despite the bad relations
it has with Moray.
I have to load the .ini file
(once for the 1st render in the session, then I close it to not be asked if
I want to reload at every export)
and start Megapov  by hand but  it is bearable ;-)
Marc
Date: 21 Mar 2006 17:19:16
Message: <44207be4@news.povray.org>
Another approach is to use a plugin, for example InsertCodeMFC.dll, and add
a camera statement.
Moray will always list it's own camera statements before any objects (or
plugins). Your second camera statement will override the first.
Date: 22 Mar 2006 04:40:00
Message: <web.44211a8a9a014eb9b1b469160@news.povray.org>
> a camera statement.
> Stephen
Stephen, do you know where to get a copy of InsertCodeMFC.dll? I lost mine
That sounds like a good technique I must steal it.
Date: 22 Mar 2006 05:04:28
Message: <4421212c@news.povray.org>
news:web.44211a8a9a014eb9b1b469160@news.povray.org...
add
> > a camera statement.
> > Stephen
> at my last HD crash. I can't find it now.
Hey Stephen! if you read other posts than Stephen's you can see I gave the
link in a former one of this thread ;-)
Marc
