POV-Ray : Newsgroups : povray.newusers : Astronomical scale space scenery: floating-point precision problem? Server Time
21 Dec 2025 07:19:09 EST (-0500)
  Astronomical scale space scenery: floating-point precision problem? (Message 1 to 5 of 5)
Subject: Astronomical scale space scenery: floating-point precision problem?
Date: 6 Mar 2006 19:40:00
Message: <web.440cd3ff38a1658e9f9718b50@news.povray.org>
I'm trying to construct some space scenery containing a few very large
objects (Sun, Earth, Moon), and a small number of space vessels (~200 m in
length).  I started out using a scale of 1 unit = 1 m, but found that large
objects in the scene disappeared - they simply weren't being rendered.  I
switched to 1 unit = 1e6 m, which I thought might be a good compromise,
which is better, but the image is very grainy when both large and small
objects are rendered in the same scene.  I think these effects must be due
to limits of floating-point precision (this is POV-Ray 3.6 on 32-bit
Windows XP).  Is there any kind of workaround for this?  I'd really like to
work to scale if possible.
Is the 64-bit version of POV-Ray likely to work better for this kind of
scenery? I am using an AMD64 system but currently have no 64-bit Windows
installation; IIRC, SSE/SSE2 has 128-bit FP registers.
Thanks in advance!
Subject: Re: Astronomical scale space scenery: floating-point precision problem?
Date: 7 Mar 2006 03:29:04
Message: <440d4450@news.povray.org>
"screwtop" <cme### [at] ihugconz> schreef in bericht
news:web.440cd3ff38a1658e9f9718b50@news.povray.org...
large
to
I am not sure if this will help you, but have a look at this message:
http://news.povray.org/436572fd%40news.povray.org
and the few following that (or even the initial discussion). You would need
version 3.6.0. Can be found on the ftp site of POV-Ray I think, or one of
the mirror sites.
Date: 7 Mar 2006 04:15:00
Message: <web.440d4dcfc7e24a1382fc96790@news.povray.org>
> large
> to
> the mirror sites.
> Thomas
Hello!
I already encountered this kind of problem. I surely comes from POV's
internal epsilons (as shown in the above-mentioned thread). So one must
think of designing scenes with reasonable range for the distances (eg
billion miles away planet/star vs milimetric objects in the foreground)
Perhaps some epsilons could re-adjusted in 3.7 (I don't know much about
POV's internals). In addition, I don't think processor-precision has much
to do with this behaviour compared to these epsilons. Maybe someone more
informed about POV's intimacy could enlighten us. Thanks to him in advance
   Bruno
Date: 7 Mar 2006 07:00:00
Message: <web.440d7585c7e24a13731f01d10@news.povray.org>
As a result of the above-mentioned thread (and another that followed on), it
was my understanding that the enhanced precision will indeed be included in
3.7. The powers that be can confirm / deny this, I'm sure.
Bill
Date: 7 Mar 2006 18:37:40
Message: <440e1944@news.povray.org>
screwtop nous apporta ses lumieres en ce 06/03/2006 19:31:
> Thanks in advance!
Look at the other replys first.
As for your CPU, 32 bits and 64 bits both have 64 bits FPU. In fact, even the latest
16 bits CPU,
those with integrated FPU, where equiped with 64 bits FPU. 64 bits is the size
required for double
presision floating point operations.
If you have the source code, you can change the epsilon value and compile it, but be
carefull not to
overdo it. As the values get smaler, you can get very close to the resolution limit
imposed by the
double presision operations. This, in turn, will lead to more rounding and
granulausity errors,
causing "random" artefacts.
BREAKFST.COM halted . . . cereal port not responding!
