POV-Ray : Newsgroups : povray.newusers : Antialiasing question Server Time
29 Sep 2024 16:13:25 EDT (-0400)
  Antialiasing question (Message 1 to 3 of 3)
Subject: Antialiasing question
Date: 9 Feb 2006 12:55:00
Message: <web.43eb8198f6bc24647d3ae5e0@news.povray.org>
Howdy-ho!
I have a question about AA. The "standard" in POV-Ray is set at 0,3, and I
can change it myself by adding i.e. +A0,1 to the command line. But I wonder
what limitations there are to this? Can I put +A0,00000000001 or something,
or will there be no difference? Please enlighten me!
In all humbleness
RH
Subject: Re: Antialiasing question
Date: 9 Feb 2006 13:43:52
Message: <3fJeILAy046DFwhN@econym.demon.co.uk>
Wasn't it RusHHouR who wrote:
>Howdy-ho!
>In all humbleness
The documentation says:
  In the default, non-recursive method (+AM1), POV-Ray initially traces
  one ray per pixel. If the color of a pixel differs from its neighbors
  (to the left or above) by at least the set threshold value then the
  pixel is super-sampled by shooting a given, fixed number of additional
  rays. The default threshold is 0.3 but it may be changed using the
  Antialias_Threshold=n.n option. When the switches are used, the
  threshold may optionally follow the +A. For example +A0.1 turns anti-
  aliasing on and sets the threshold to 0.1.
  The threshold comparison is computed as follows. If r1, g1, b1 and r2,
  g2, b2 are the rgb components of two pixels then the difference
  between pixels is computed by
    diff = abs(r1-r2) + abs(g1-g2) + abs(b1-b2)
  If this difference is greater than the threshold then both pixels are
  super-sampled. The rgb values are in the range from 0.0 to 1.0 thus
  the most two pixels can differ is 3.0. If the anti-aliasing threshold
  is 0.0 then every pixel is super-sampled.
So the furthest you can push it with the non-recursive method is +A0.0.
The recursive method +AM2 goes much deeper, and takes longer.
Mike Williams
Gentleman of Leisure
Date: 10 Feb 2006 20:30:00
Message: <web.43ed3dc982f2e4e747d3ae5e0@news.povray.org>
Mike Williams <nos### [at] econymdemoncouk> wrote:
> the answer
> Mike Williams
Thanks! =)
