POV-Ray : Newsgroups : povray.newusers : trace function Server Time
8 Apr 2026 21:16:32 EDT (-0400)
  trace function (Message 1 to 5 of 5)
Subject: trace function
Date: 22 Jan 2006 07:30:00
Message: <web.43d37a9798a2d8cb731a6f9e0@news.povray.org>
hi, every body.
1. As new user i want to know how to use the trace function, and where i can
   get the results of the point of intersection.
2. pls if it possibble to get a simple exmple.
3. I didn't understand the exmple in the tutorial.
4. lots of thanks.
shimon
Subject: Re: trace function
Date: 22 Jan 2006 10:10:37
Message: <43d3a06d@news.povray.org>
shimon_a10 nous apporta ses lumieres en ce 22/01/2006 07:29:
> hi, every body.
> 4. lots of thanks.
> shimon
The trace() function return coordinates that you should attribute to a variable:
#declare Object = put your object's deffinition, the name is up to you
#declare NormalVector = <0,0,0>;
#declare Point = trace(Object, Start, End, NormalVector);
The variable "Point" contains the desired coordinates.
The variable "NormalVector" contains the normal at that point, zero if the trace
missed the object.
The normal been a unit lenght direction vector perpendicular to the surface of the
object.
Hint: it's always recomended to use at least 1 upper case letter, usualy the first, in
variable
name. ALL key-words are lower case only and all lower case variables can conflict with
the current
ones or future ones.
Eat one live toad the first thing in the morning and nothing worse will happen to
you the rest of the day.
Date: 22 Jan 2006 15:05:01
Message: <web.43d3e501b5dd53695a8ded0@news.povray.org>
> > hi, every body.
> > 4. lots of thanks.
> > shimon
missed the object.
object.
in variable
with the current
> Alain
Hi, Alain and lots of thanks for your help.
1. first i want to ask how can i see the value of Point (like in matlab, if
   i want to debug my plan).
2. second, what do you mean with your Hint.
3. and last, thanks again.
5. bye.
shimon
Date: 22 Jan 2006 15:20:00
Message: <web.43d3e87cb5dd53695a8ded0@news.povray.org>
> > hi, every body.
> > 4. lots of thanks.
> > shimon
missed the object.
object.
in variable
with the current
> Alain
Hi, Alain and thanks for your help.
1. first, i need more explanation about the normal vector. why you gave it
   the value <0,0,0>?.
2. second' i want to see the value of variable "Point" (like in matlab, if i
3. what do you mean with the Hint.
4. thanks again.
shimon
Date: 23 Jan 2006 13:20:11
Message: <43d51e5b$1@news.povray.org>
shimon_a10 nous apporta ses lumieres en ce 22/01/2006 15:18:
missed the object.
object.
in variable
with the current
>>Alain
>    the value <0,0,0>?.
> 4. thanks again.
> shimon
1. I must predeffine the variable to be used. A value of <0,0,0> is a good padding
value and the
result if the trace never encounter the target object.
2. Look at the repply from Chris in the debug thread.
3. What I mean is that when you make your scene and use variables or other
identifiers, it's better
that the name contains upper case characters, at least one, usualy the first. It's a
recommended
practice that many begginers tend to forget. It may not be of immediate use in your
case, but good
to know anyway.
