POV-Ray : Newsgroups : povray.newusers : Two remaining problems for planetary scenes Server Time
29 Sep 2024 16:11:06 EDT (-0400)
  Two remaining problems for planetary scenes (Message 1 to 4 of 4)
Subject: Two remaining problems for planetary scenes
Date: 1 Jan 2006 12:55:00
Message: <web.43b816026526bd51c89ad05e0@news.povray.org>
FIRST OF ALL: I am french, so excuse me if my english is not perfect...
I have made a serie of include files to make planetary scenes.
The first and most important file is planet.inc: it declares
"object{planet}". It is a 1 pov-unit radius sphere scaled by the parameter
"planet_dimensions" (for example <6378.1,6356.8,6378.1> for the Earth,
where 6378.1 is the equatorial radius and 6356.8 is the polar one). The
texture is declared by "planet_texture".
FIRST PROBLEM:What shoud I put in the finish{} properties of
"planet_texture" to have a good-looking (is that the word) planet? The only
thing I am sure for now is that the ambient value must be 0.
SECOND PROBLEM:I have two maps, one representing the Earth land mass
topography above the sea (see http://www.space-graphics.com/e43_flat.htm)
and the other representing the Earth global ocean/landmass mask (see
http://www.space-graphics.com/e43_mask.htm). For the second map, the white
represents the oceans and rivers while the black represents the landmass.
I would like the landmass and the oceans to have different finish{}
properties so that only the ocean reflects well the sun.
For the moment I declare the earth texture like that:
#declare planet_texture=texture{
pigment{
image_map{
jpeg "Earth_map.jpg" map_type 1
finish{
ambient 0
//WHAT SHOULD I PUT HERE THEN???...
and in planet.inc I have:
#declare planet=sphere{
0
1
texture{
planet_texture
scale planet_dimensions
Erwan Le Gac
Subject: Re: Two remaining problems for planetary scenes
Date: 1 Jan 2006 17:22:19
Message: <43b8561b$1@news.povray.org>
"elegac" <e.l### [at] voilafr> wrote in message
news:web.43b816026526bd51c89ad05e0@news.povray.org...
A specular hilight would be something to add for the sunlight to be seen
reflected. Mostly for the water, but also a little for land. Something maybe
like:  specular 0.05 roughness 0.1
You might need to adjust the amount (size) showing for the distance your
camera is planned to be located from the planet surface. There's an effect
called heiligenschein, or holy light, like a halo created on dewey grass
around the shadow of your head but I'm not sure if this is the same thing.
> SECOND PROBLEM:
The black and white landmass/water map can be used in a material_map, then
applied as the uppermost layer of textures over the other image_map texture
but using transparent pigments to still see the other map through it.
Something like this:
#declare Planet_Land_Texture=
     image_map {
      jpeg "earthmap.jpg"
         map_type 1 // spherical
         interpolate 2 // pixel blending
    finish {
        ambient 0
        diffuse 0.5
#declare Planet_Water_Texture=
    material_map {
        png "earthlandwatermap.png"
        map_type 1
        interpolate 2
        texture { // first color index (black)
                rgbt 1 // clear
        // add textures between, if any more index values exist
        texture { // next color index (white?)
                rgbt 1
            normal { // makes water unsmooth
                wrinkles 0.1 scale 0.01
            finish {
                ambient 0
                diffuse 0
                specular 0.4 roughness 0.02
sphere {
 0,1
  texture {Planet_Land_Texture}
// cannot layer the material texture into 1st so 2nd sphere is needed
sphere {
 0,1.0001 // slightly larger to cover other sphere
  texture {Planet_Water_Texture}
 location -3*z
 look_at 0
light_source {
 -123*z, 1
 rotate <30,30,0>
// looks like this should work okay with the image files you told of (I
renamed them).
You might also want to try adding a normal{bump_map{[image file here]}} to
the land part by using an elevation-based map, unless you'll only see the
planet from far away.
Good luck with it! Ask more questions if you need any help. Someone else
might even have other ideas for you.
Date: 2 Jan 2006 08:50:00
Message: <web.43b92eeea386411c89ad05e0@news.povray.org>
FIRST PROBLEM: SOLVED!
It look good now, thanks! Look at
http://cjoint.com/data/bcoUFJE77o_Earth.jpg
(I've added an atmosphere with my "atmosphere.inc" include file)
Now let's see the second problem...
Erwan
Date: 9 Jan 2006 10:20:00
Message: <web.43c27e52a38641182fc96790@news.povray.org>
> Erwan
I have another solution to your problem: use your landmass/water map as a
mask for a texture map (ie pigment pattern)) as follows:
#declare Planet_Land_Texture =
     image_map {
      jpeg "earthmap.jpg"
    finish {
        // WHATEVER, but, according to me,  land should be kept as it is in
the image.
#declare Planet_Water_Texture = texture
    // WHATEVER: blue pigment with reflection and/or specular or image map.
#declare Planet = sphere
    0, 1
    texture
        pigment_pattern // Here is the trick
            image_pattern
                map_type 1
        texture_map
            // Entries may be inverted according to the way
"earthlandwatermap.png" encodes land and water. Here, zeros are for land
and ones for water (threshold set to 0.5).
            [0.5 Planet_Land_Texture]
            [0.5 Planet_Water_Texture]
object {Planet}
Regards
    Bruno
