POV-Ray : Newsgroups : povray.newusers : High resolution images Server Time
20 Nov 2025 01:49:04 EST (-0500)
  High resolution images (Message 1 to 3 of 3)
Subject: High resolution images
Date: 28 Nov 2005 15:00:00
Message: <web.438b61985e84fbedb7afe1280@news.povray.org>
Hi!
I got some images with POV-RAY. I want to know how much dpi picture I got
with this program. If it is less than 600dpi, is there any way to make
higher resolution?
Thank you in advance.
Subject: Re: High resolution images
Date: 28 Nov 2005 15:08:45
Message: <438b63cd$1@news.povray.org>
> higher resolution?
Please read the thread:
Date: Fri, 16 Sep 2005 10:14:29 EDT
Newsgroups: povray.general
Message-ID: <web.432ad3458a10e857703346660@news.povray.org>
Subject: about DPI and resolution....???? help !
Xref: news.povray.org povray.general:58903
It discusses that topic (and your misconception) in detail.
	Thorsten
Date: 29 Nov 2005 03:12:18
Message: <438c0d62@news.povray.org>
> higher resolution?
  DPI with regard to what? POV-Ray creates an image of x*y pixels (specified
by the user). What on earth could a "DPI" value affect that x*y pixels image?
  A DPI value is used for example by a printer to *scale* an image when
printing it. If you print a 1024x768 image at 300 DPI the printer will
scale the pixels larger than if you print it at 600 DPI. The contents
of the image will not change, only the size of the pixels in the paper
(ie. lower DPI -> bigger pixels).
  POV-Ray just renders an image with certain amount of pixels (which you
can specify). Whatever you do with those pixels afterwards is completely
up to you. If you want to print them at 600 DPI there's nothing stopping
you from doing so. Just do it.
  I can't even start to imagine how a DPI value should change the output
image created by POV-Ray. After all, the image resolution is in pixels,
not in inches.
