POV-Ray : Newsgroups : povray.newusers : Image Maps Server Time
21 Dec 2025 10:44:39 EST (-0500)
  Image Maps (Message 1 to 6 of 6)
Subject: Image Maps
Date: 12 Nov 2005 09:20:01
Message: <web.4375f8ef21f939cb3cc62c290@news.povray.org>
I want to create an image map for a sphere in photoshop for a pool ball i.e.
a colour, a white circle with a number in it.  If I create a sphere <0,0,0>
1.0 in pov-ray what size does my planar map in photoshop have to be to
avoid any wrapping?  Is there any way to avoid wrapping round an object?
Thanks.
Subject: Re: Image Maps
Date: 12 Nov 2005 13:22:47
Message: <K0ehyCAxLjdDFwM3@econym.demon.co.uk>
The size of the image in photoshop has no effect at all on whether the
image gets wrapped. The documentation says
  By default, the image is mapped onto the x-y-plane. The image is
  projected onto the object as though there were a slide projector
  somewhere in the -z-direction. The image exactly fills the square area
  from (x,y) coordinates (0,0) to (1,1) regardless of the image's
  original size in pixels. If you would like to change this default you
  may translate, rotate or scale the pigment or texture to map it onto
  the object's surface as desired.
You need to translate the pigment by <-0.5,-0.5,0> and scale it by 2 to
get it to fit once onto sphere{<0,0,0>,1}.
Mike Williams
Gentleman of Leisure
Date: 13 Nov 2005 00:50:53
Message: <kurtzlepirate-E4DFD3.06505313112005@news.povray.org>
In article <web.4375f8ef21f939cb3cc62c290@news.povray.org>,
 "the_ajj" <nomail@nomail> wrote:
::I want to create an image map for a sphere in photoshop for a pool ball i.e.
::a colour, a white circle with a number in it.  If I create a sphere <0,0,0>
::1.0 in pov-ray what size does my planar map in photoshop have to be to
::avoid any wrapping?  Is there any way to avoid wrapping round an object?
::Thanks.
any size you like but image must have width = 2 x height.
klp
Date: 15 Nov 2005 02:22:26
Message: <43798cb2$1@news.povray.org>
No; regardless of an image's size, it will be treated the same way by
POV-Ray. This means it will be squeezed into the unit square from <0,0,0> to
<1,1,0>, even if doing so changes its proportions. (If spherical mapping is
used, the image will similarly wrap all the way around the sphere no matter
what its width or height is.) It's up to the user to resize the image as
necessary.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 16 Nov 2005 13:20:39
Message: <kurtzlepirate-2707F1.19203916112005@news.povray.org>
In article <43798cb2$1@news.povray.org>, "Slime" <fak### [at] emailaddress>
wrote:
::> any size you like but image must have width = 2 x height.
::No; regardless of an image's size, it will be treated the same way by
::POV-Ray. This means it will be squeezed into the unit square from <0,0,0> to
::<1,1,0>, even if doing so changes its proportions. (If spherical mapping is
::used, the image will similarly wrap all the way around the sphere no matter
::what its width or height is.) It's up to the user to resize the image as
::necessary.
:: - Slime
:: [ http://www.slimeland.com/ ]
you're wrong. please see my samples in p.b.i
klp
Date: 18 Nov 2005 08:40:00
Message: <web.437dd897bef31fb5a43155f60@news.povray.org>
Thanks everyone.....the argument continues in the images newsgroup !
