POV-Ray : Newsgroups : povray.newusers : trying to fade an object Server Time
19 Aug 2025 08:54:45 EDT (-0400)
  trying to fade an object (Message 1 to 3 of 3)
Subject: trying to fade an object
Date: 25 Sep 2005 15:50:00
Message: <web.4336ff63c2a0a642bb5b55ca0@news.povray.org>
I am trying to render an action sequence. What I'd like to do is have my
"hero" in two positions, but the first location I want him to be somewhat
transparent so to show a motion from first to second position. I tried
adding filter to the called object but didn't notice a change. how do I
fade this object?
Subject: Re: trying to fade an object
Date: 26 Sep 2005 14:07:17
Message: <433838d5@news.povray.org>
You have to make sure you add filter/transmit to *all* your pigments. It
is not possible to do something like that:
#declare Hero = object {
   // your object
   texture { ... }
object {
   Hero
   pigment { rgb 1 filter 0.9 }
because that would use the last texture only for non-textured parts of
the hero object. One way is to do sth like this:
//hero.inc
#ifndef(FILTER) #declare FILTER = 0; #end
     pigment { ... filter FILTER }
//main scene file
#include "hero.inc"
object { Hero translate somewhere }
#declare FILTER = 0.5;
#include "hero.inc"
object { Hero translate somewhereelse }
You'll have to include your hero file anew each time you change the
FILTER setting, because it's evaluated at parse-time. An other option
would be to let a macro create your hero object and call the macro with
an appropriate filter parameter.
HTH,
Florian
Date: 27 Sep 2005 02:17:20
Message: <4338e3f0@news.povray.org>
Note that if you apply a transmit to the object, you will start seeing
the inner surfaces (which are normally occluded). In some cases that might
not be desirable. If it's not, then the problem is harder.
