POV-Ray : Newsgroups : povray.newusers : a question about radiosity Server Time
29 Sep 2024 20:15:58 EDT (-0400)
  a question about radiosity (Message 1 to 5 of 5)
Subject: a question about radiosity
Date: 16 Sep 2005 16:00:01
Message: <web.432b2347850fefba73333a0@news.povray.org>
Hi
Could someone please explain, how pretrace_start affects the quality of the
final image? Radiosity pretrace phase is mentioned quite shortly in
documentation and tutorials, and only pretrace_end gets explained. As far
as I understand, the difference between pretrace_start and pretrace_end
specifies the number of pretrace steps. E.g if I specify pretrace_start
0.08 and pretrace_end 0.01 there will be 4 steps. But will there be any
difference if I e.g. specify pretrace_start the same as pretrace_end, and
there will be only one step?
Andrey
Subject: Re: a question about radiosity
Date: 16 Sep 2005 16:24:21
Message: <432b29f5$1@news.povray.org>
The pretracing does preliminary passes on the scene to place and gather
radiosity sample for reuse. The idea is that when beginning with broad
sweeps, you begin with placing samples all around the image for starters,
and then, the more iterations (and also the more detailed the pretrace gets)
you do, the more samples are placed where needed. It's a refinement process.
As with all refinement processes, starting with highly detailed settings
right away doesn't harm, though I think it is better to have a few passes
for the radiosity algorithm to properly figure out where to place samples.
What I personally like about the pretrace is that you can get a good feel if
the lighting is right, cause you get a rough render very fast.
Tim
"Tim Nikias v2.0"
Date: 16 Sep 2005 17:51:02
Message: <432b3e46$1@news.povray.org>
Andrey Platonov nous apporta ses lumieres en ce 2005-09-16 15:57:
> Hi
> Andrey
In some cases where you get artefacts near corners, a slight change in pretrace_start
may supress
those. Changing the pretrace_start value cause the location of the samples to shift
slightly and
possibly miss the problem pixel(s).
Using smaller pretrace_end can realy help improve the quality of the radiosity while
still using
lower, and faster, parameters.
I like to use a variable to set my pretrace, by itself for _start, divided by a power
of 2 for the _end.
Date: 16 Sep 2005 17:53:03
Message: <432b3ebf@news.povray.org>
"Tim Nikias" <JUSTTHELOWERCASE:timISNOTnikias(at)gmx.netWARE> wrote in
message news:432b29f5$1@news.povray.org...
> gets)
> process.
> if
   Thank you Tim.
     ~Steve~
> Regards,
> Tim
> "Tim Nikias v2.0"
> Homepage: <http://www.nolights.de>
Date: 17 Sep 2005 13:25:01
Message: <web.432c511331fecc0773333a0@news.povray.org>
Thanks everybody.
Andrey
