POV-Ray : Newsgroups : povray.newusers : Seeing artifacts when too many translucent surfaces overlap Server Time
20 Mar 2026 12:24:07 EDT (-0400)
  Seeing artifacts when too many translucent surfaces overlap (Message 1 to 4 of 4)
Subject: Seeing artifacts when too many translucent surfaces overlap
Date: 15 Sep 2005 22:30:01
Message: <web.432a2d2e64f03c89fc5d75160@news.povray.org>
Below is simple code that creates a 2D array of identical translucent boxes.
 When I look at the array from such an angle that I'm looking through
several surfaces, I see opaque artifacts.  Even stranger: The color of the
artifacts gets *darker* as I increase the transmit value (i.e. make the
objects more transparent).  If I decrease the transmit value, making the
objects more opaque, the dark artifacts go away.  However, I don't want
less translucent objects!
Is there any way to generate multiple translucent objects without producing
this problem?  I'm running POV-Ray 3.6.1a.icl8.win32 under Win XP Pro.
Thanks!
White Ryder
  background { color 2*MidnightBlue }
  camera
    location <0, 2, -6>
    look_at  <0, 1,  0>
  light_source { < -2,   4, -6>  color 1.5*White }
  // Basic translucent box
  #declare TBox =
  box
    <-1,-1,-1>, < 1, 1, 1>
    no_shadow
    pigment { color 2*White transmit 0.9}
  // Create 2D array of TBoxes
  #declare X_spacing = 4;
  #declare Z_spacing = 3; // see artifact when spacing>2; when spacing=2
faces coincide, no artifact
  #declare Num_Xs=2;
  #declare Num_Zs=3;
  #declare TArray=
  union
    #declare Z_index=0;
    #while (Z_index<Num_Zs)
      #declare X_index=0;
      #while (X_index<Num_Xs)
        object
          TBox
          translate x*X_spacing*X_index
          translate z*Z_spacing*Z_index
        #declare X_index = X_index + 1;
      #declare Z_index = Z_index + 1;
  // Display result
  object
    TArray
    translate x*-2
Subject: Re: Seeing artifacts when too many translucent surfaces overlap
Date: 15 Sep 2005 22:40:00
Message: <web.432a2fe17848af12dc13759e0@news.povray.org>
http://www.povray.org/documentation/view/3.6.1/264/
Date: 16 Sep 2005 17:40:27
Message: <432b3bcb$1@news.povray.org>
White Ryder nous apporta ses lumieres en ce 2005-09-15 22:25:
> Thanks!
> White Ryder
You are reaching the max_trace_level. When the boxes are more opaque, the adc_bailout
kiks in giving
you a color.
Add this line:
#global_settings{max_trace_level 15}
Adjust the value up until you have no more black spots. You can calculate the required
value easily.
Count the number of boxes you have, multiply by 2 (each box have 2 surfaces) then add
1 for the
backbround or whatever is behind all the boxes.
Read section 2.3.3.7 Max_Trace_Level in the documentation (or read it again).
Date: 17 Sep 2005 20:45:01
Message: <web.432cb7a77848af12fc5d75160@news.povray.org>
Thank you very much for your help!  That fixed the problem.
