POV-Ray : Newsgroups : povray.newusers : Problem with colliding elements Server Time
13 Oct 2025 14:00:11 EDT (-0400)
  Problem with colliding elements (Message 1 to 5 of 5)
Subject: Problem with colliding elements
Date: 9 Aug 2005 07:20:00
Message: <web.42f89130212c59aa726bd13c0@news.povray.org>
Hi all,
I just started with POV-Ray yesterday and created the code as seen on te
bottom of this message.
It creates 9 superellipsoid's with various heights.
I see two problems here and would like to know if these are bugs or
something I can easily resolve.
1) If the sides of the superellipsoid's collide with other elements I see
these flat parts probably indicating the curve of the superellipsoid's. But
I wanted them to just stay orange.
2) If the sides of the superellipsoid's collide with each other (or even if
you out them inside each other) you get those nasty black areas.
Note: I did not get this second effect when I used random colors for the
superellipsoid's.
Anyone care to comment on this and enlighten me ?
Code:
camera
 location <-4, 4, -4>
 look_at <4, 0, 4>
 up <0, .9, 0>
 right <1.6, 0, 0>
light_source
 <-75, 120, -25>
 rgb 1
plane
 y, 0
 pigment
  checker
  rgb 1
  rgb <.9, .9, .9>
plane
 x, 10
 pigment
  rgb 1
plane
 z, 10
 pigment
  rgb 1
#declare randomSeed = seed (2005);
#declare roundedBox =
 superellipsoid
  <0.2, 0.2>
  pigment
   rgb <1, .9, .8, .99>
  finish
   ambient 0.15
   diffuse 0.85
   phong 1
  translate <0, 1.001, 0>
#declare xCount = 0;
#declare zCount = 0;
#while (xCount < 3)
 #while (zCount < 3)
  object
   roundedBox
   translate <xCount * 2.0001, 0, zCount * 2.0001>
   scale <1, rand(randomSeed) * 2, 1>
   pigment
     #declare zCount = zCount + 1;
 #declare xCount = xCount + 1;
Subject: Re: Problem with colliding elements
Date: 9 Aug 2005 07:59:04
Message: <p+uJwGA$pJ+CFw1m@econym.demon.co.uk>
Wasn't it Numb-C who wrote:
>Hi all,
>superellipsoid's.
(1)All the colour in a POV object is at the surface. When part of the
surface goes below the floor, you lose the contribution from its colour.
One way to work round this is to chop off the bottom of the rounded box
just above the floor, like this:
#while (xCount < 3)
 #while (zCount < 3)
  intersection {
   object
    {roundedBox
    plane {-y,-0.001}
    pigment {rgbf <1, .9, .8, .99> }
    finish {ambient 0.15 diffuse 0.85 phong 1}
(2)The nasty black areas are points where you've reached the current
max_trace_level.
For efficiency, POV doesn't usually trace rays further than 5
intersections because it can take a long time and usually the
contribution from points further than that are negligible. I guess that
your random colours had generally lower transparency so you can't see
through the 5 layers.
Try adding
        global_settings {max_trace_level 20}
Mike Williams
Gentleman of Leisure
Date: 9 Aug 2005 08:22:47
Message: <42f8a017@news.povray.org>
"Numb-C" <ann### [at] philipscom> wrote in message
news:web.42f89130212c59aa726bd13c0@news.povray.org...
> Hi all,
  Hi
  Just add this before your camera:
  global_settings {
   max_trace_level 50  }
   ~Steve~
Date: 9 Aug 2005 08:24:23
Message: <42f8a077@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:42f8a017@news.povray.org...
    ...and Mike explained it well.  ;)
    ~Steve~
Date: 9 Aug 2005 08:40:00
Message: <web.42f8a353d70a9d8e726bd13c0@news.povray.org>
Thanks both for your quick and clear explanations. I will try this out as
soon as I get home later today.
