POV-Ray : Newsgroups : povray.newusers : How to create a beam inside a glass? Server Time
29 Sep 2024 22:20:21 EDT (-0400)
  How to create a beam inside a glass? (Message 1 to 10 of 13)
Subject: How to create a beam inside a glass?
Date: 21 May 2005 12:05:02
Message: <web.428f5bf3650d078490ff0fdd0@news.povray.org>
The glass has a form of cylinder and the refraction index 1.33(ior 1.33).
How to create a beam inside it?
Thanks.
Subject: Re: How to create a beam inside a glass?
Date: 21 May 2005 13:36:03
Message: <428f7183$1@news.povray.org>
"Ziyan" <beg### [at] hotmailcom> wrote in message
news:web.428f5bf3650d078490ff0fdd0@news.povray.org...
Add 'media' for the light beam to interact with the object. Maybe something
like the following:
global_settings {
    assumed_gamma 1.0
cylinder {
    0, 2*y, 1
    hollow // must be hollow
        rgbt 0.9 // not entirely transparent
    interior {
        ior 1.33
        media {
            scattering {
                1, 1.5 // isotropic type, and amount of scatter
                extinction 0.5 // fades out if >0
light_source {
    <1,9,1>, 1
    cylinder // for the "beam" appearance, otherwise use 'spotlight'
    point_at <0,0,0>
    radius 0.1
    falloff 0.2
    location <0,1,-4>
    look_at y
Date: 21 May 2005 19:15:00
Message: <web.428fc0b14282c60c90ff0fdd0@news.povray.org>
Thank you very much.
Then how could I create a beam through a piece glass? I mean the length of
beam langer than that of glass. The beam inside and outside of glass should
be all visible.
Could you help me?
Date: 21 May 2005 19:25:27
Message: <0rgv815vd5rlca3bvfdn1nn4t6u0tqvt4h@4ax.com>
On Sat, 21 May 2005 19:13:53 EDT, "Ziyan" <beg### [at] hotmailcom>
>be all visible.
>Could you help me?
Surround the cylinder with a box that has scattering media, use
photons. Look at optics.pov in the sample scenes.
Regards
Date: 21 May 2005 19:45:00
Message: <web.428fc7304282c60c90ff0fdd0@news.povray.org>
then I created a beam like that
light_source {<0, 0, 68>
    color rgb < 1.2, 1, 1.5>
    cylinder
    point_at <0,0,-68>
    photons {refraction on reflection on}
    translate <-27.5,-0.25,0>
cylinder{<0,0,-68>, < 0, 0, 68>,0.5
    hollow
    texture {pigment {color rgbf 1}}
    interior {
        media {
            scattering {1, color Red extinction 0}
            method 3
            intervals 1 samples 4}}
    photons {target}
    translate -27.5*x
// to pass through the object
#declare A = merge {object{cylinder {-65*z,65*z,0.4}}
                    object{box {<-0.4,-0.25,-65>,<0.4,0.25,65>}
                           translate 0.25*y  }}
object {A
        translate <-27.5,0,0>
        hollow
        color rgbf 0.7}
        interior {
        ior 1.55
        media {
            scattering {1, 1.5
                extinction 0.5
but nothing happens.....and even a Merge has separated surface.
> >be all visible.
> >Could you help me?
> Regards
>         Stephen
Date: 21 May 2005 20:28:52
Message: <rfkv81dbqoermkgpcklfljhkmihtvvh4mb@4ax.com>
On Sat, 21 May 2005 19:41:36 EDT, "Ziyan" <beg### [at] hotmailcom>
I did a quick scene in Moray so look out for different coordinate
system. (Z is up) I hope this helps.
BTW I am not renowned for my textures or media.
default {
    pigment { rgb <1,0,0> }
#declare Checkered_1 =
   material  // Checkered_1
      texture
         pigment
            checker
               color rgb <0.882353, 0.882353, 0.882353>
               color rgb <0.952941, 0.952941, 0.952941>
         finish
            ambient 0.1
         scale  6.0
#declare Scattering =
   material  // Scattering
      texture
         pigment
            color rgbt <0.531233, 0.531233, 0.531233, 1.0>
      interior
         media  // MyAtmosphere_1_1
            variance 1.0/128.205128
            scattering
               1 ,  rgbt <0.03, 0.03, 0.03, 1.0> // isotropic
scattering
               extinction 0.25
#declare Scattering_1 =
   material  // Scattering_1
      texture
         pigment
            color rgbt <0.0, 0.0, 0.0, 1.0>
      interior
         ior 1.3
         media  // MyAtmosphere_1_1_1
            scattering
               1 ,  rgbt <1.0, 1.0, 0.0, 1.0> // isotropic scattering
               extinction 0.25
global_settings {
  adc_bailout 0.003922
  ambient_light <1.0,1.0,1.0>
  assumed_gamma 1.9
  hf_gray_16 off
  irid_wavelength <0.247059,0.176471,0.137255>
  max_intersections 64
  max_trace_level 10
  number_of_waves 10
  noise_generator 2
  charset ascii
  photons {
    adc_bailout       0.01
    spacing           1.0
    gather            20, 100
    media             0, 1.0
    jitter            0.4
    max_trace_level   5
    autostop          0.5
    radius            0.0
    expand_thresholds 0.2, 35.0
background { color <0.000,0.000,0.000> }
camera {  //  Camera Camera01
  location  <      0.059,     -12.191,       4.009>
  sky       <    0.00000,     0.00000,     1.00000> // Use right
handed-system
  up        <        0.0,         0.0,         1.0> // Where Z is up
  right     <    1.38192,         0.0,         0.0> // Right Vector is
adjusted to compensate for spherical (Moray) vs. planar (POV-Ray)
aspect ratio
  angle         54.40000    // Vertical      40.800
  look_at   <      0.039,      -0.151,       0.036>
// *******  L I G H T S *******
light_source {   // Spotlight Spotlight001
  <0.0, 0.0, 0.0>
  color rgb <0.000, 1.000, 0.000>*10
  spotlight
    point_at  <0.0, 0.0, -2.000>
    falloff    1.268  // outer radius (in deg)
    radius     1.238  // inner radius
    tightness  0.000
  media_attenuation on
  rotate 90.0*y
  translate  7.786407*x
light_source {   // Light001
  <0.0, 0.0, 0.0>
  color rgb <1.000, 1.000, 1.000>
  media_interaction off
  photons {
  translate  <0.984692, -14.212549, 19.073553>
light_source {   // Spotlight Spotlight002
  <0.0, 0.0, 0.0>
  color rgb <1.000, 0.000, 0.000>*10
  spotlight
    tightness  0.000
  rotate 50.074482*y
  translate  <4.411019, 0.0, 4.027452>
// ********  OBJECTS  *******
plane { // Plane001
  z,0
  material {
    Checkered_1
  photons {
    target 1.0
  translate  <-0.038357, 0.0, -3.260318>
box { // Cube001
  <-1, -1, -1>, <1, 1, 1>
  material {
    Scattering
  hollow
  scale 12.430292
cylinder { // Cylndr001
  <0,0,1>, <0,0,0>, 1
  material {
    Scattering_1
  hollow
  photons {
    reflection on
    refraction on
  scale <1.0, 1.0, 3.723325>
  rotate 90.0*y
  translate  <-1.572624, 0.0, -0.038357>
Regards
Date: 21 May 2005 23:53:14
Message: <4290022a$1@news.povray.org>
"Stephen McAvoy" <mca### [at] aolcom> wrote in message
news:rfkv81dbqoermkgpcklfljhkmihtvvh4mb@4ax.com...
Well, Stephen, probably good enough, though, eh? One might say, 'Practice
makes perfect, but never in POV'.
I tried your example, changed the scattering and extinction so the beams of
light show up in a much better way.
Don't know why Moray won't keep those decimals trimmed. Guess that's to make
it read less human. Ha ha. Also, the transmit it has in scattering colors is
ignored by POV, FAIK, unless anything has changed lately.
I needed to fix a few lines that word wrapped, so hopefully Ziyan has gotten
around that, if it happened. And just as a side note, I'm using the new beta
of 3.7 and it doesn't like hf_gray_16 being in there, nor the
max_intersections. No idea why, ATM, just pointing this out.
So here's those medias (only) for you, Ziyan:
   material  // air or atmosphere
      texture
         pigment
            color rgbt <0.5, 0.5, 0.5, 1.0>
      interior
            variance 1.0/128
            scattering
               1 ,  rgb <0.3, 0.3, 0.3> // 10X more now
               extinction 0.1 // less extinction than before
   material  // cylinder object
      texture
         pigment
      interior
         ior 1.3
            variance 1.0/128
            scattering
               1 ,  rgb <0.5, 0.5, 0.5> // less scatter now
               extinction 0.5 // more extinction here
Date: 22 May 2005 00:35:38
Message: <42900c1a$1@news.povray.org>
When Stephen said surround the cylinder by a box he meant a box that
surrounds a large part of the scene being rendered, not just around the
cylinder. Not sure if you understood that, because looking at your script it
appears that you were only containing the narrow long cylinder and not
making a *room* with it in which to place the cylinder.
Of course, I'm only speculating on what your trying to make and so maybe you
*do* want a close-fitting box around the cylinder. Anyway, guess I'm saying
I can't understand the intent of the scene you're putting together so I
can't go further with helping about the objects in it.
However, back to media... I should have made it a point to tell you the
scattering {1,1.5 extinction 0.5} could prove very obscuring when in large
containers holding it. That 1.5 (or rgb 1.5, which it implies) essentially
blots out light over a very short distance along the camera line-of-sight.
It'll take practice to fit the proper values to the scale of the scene, so
change the scattering color and extinction numbers to whatever appears
correct for the situation.
Another thing, I noticed you left off radius and falloff (and tightness) in
the 'cylinder' light source. Unless you want the defaults of radius 0.75,
falloff 1.0 and tightness 0 (sharpest, brightest edged) then you'll probably
want to adjust those (I had to look up the defaults so hopefully that is
still correct).
And, like Stephen said, looking at the sample scene files can really help.
Let us know how you're progressing with the "beam inside glass". Feel free
to ask more questions.
Bob Hughes
Date: 22 May 2005 08:40:01
Message: <web.42907cbf4282c60c90ff0fdd0@news.povray.org>
Thank you, Bob and Stephen for all your help. I'm so appreciated when you
could solve my problem as I'm layman and not familiar with POV.
I created an object as following
#declare A = merge {object{cylinder {55*z,65*z,0.4}}
                    object{box {<-0.4,-0.25,55>,<0.4,0.25,65>}
                           translate 0.25*y  }}
#declare B = difference{box {<-0.5,-0.5,55>,<0.5,0.5,65>}
                        object {A}}
A with ior=1.55 and B with ior=1.438
now I want to create a beam through this object to simulate the refraction
and get the beam which comes out from the object.
I utilized all your work and made this, but it seems to be wrong.
global_settings {
  assumed_gamma 1.9
  hf_gray_16 off
  max_trace_level 10
  number_of_waves 10
  noise_generator 2
  charset ascii
  photons {
    adc_bailout       0.01
    spacing           1.0
    gather            20, 100
    media             0, 1.0
    jitter            0.4
    max_trace_level   5
    autostop          0.5
    radius            0.0
//Camera
         location <0,0,67>
         angle 120
         up 1*y
         right 1.333*x
         look_at <0,0,66>
background { color rgb <0, 0, 0> }
//Scattering
      texture
         pigment
      interior
            scattering
               1 ,  rgbt <0.03, 0.03, 0.03, 1.0> // isotropic scattering
               extinction 0.25
      texture
         pigment
      interior
         ior 1.55
            variance 1.0/128
            scattering
#declare Scattering_2 =
      texture
         pigment
      interior
         ior 1.438
            variance 1.0/128
            scattering
//Checker
      texture
         pigment
            checker
         finish
            ambient 0.1
         scale  6.0
//Lights
  <0.0, 0.0, 0.0>
  photons {
  translate  <2, 2, 0>
light_source {<0, 0, 90>
    color rgbt Red*10
    spotlight
    falloff 0.268  // outer radius (in deg)
    radius     0.238
    tightness  0.000
    point_at <0,.5,68>
box{<-5,-5,-80>, < 5, 5, 80>
    material {
    Scattering
  hollow
    translate -27.5*x
//Plane
plane { // Plane001
  y,-2
  material {
    Checkered_1
  photons {
    target 1.0
//Object
                           translate 0.25*y  }}
                        object {A}}
object {A
        material {
    Scattering_1
  hollow
  photons {
    reflection on
    refraction on
object { B
         material {
    Scattering_2
  hollow
  photons {
    reflection on
    refraction on
Any ideas?
Thank you again.
Date: 22 May 2005 08:45:00
Message: <web.42907e494282c60c90ff0fdd0@news.povray.org>
object A has a separated surface between box and semicircle, and B has
neither refraction nor reflection. And ideas?
