POV-Ray : Newsgroups : povray.newusers : Ortho camera help needed Server Time
20 Mar 2026 15:54:54 EDT (-0400)
  Ortho camera help needed (Message 1 to 4 of 4)
Subject: Ortho camera help needed
Date: 6 Apr 2005 10:35:00
Message: <web.4253f2d97553ced11f34f480@news.povray.org>
I am currently trying to create a set of graphics with a certain
step along the edges. Using a square tile, I want to rotate the
camera, in ortho view, so that the tile will look like this:
000000000011110000000000
000000001111111100000000
000000111111111111000000
000011111111111111110000
001111111111111111111100
As you can see, this would allow for a perfect fit between the tiles.
Unfortunately, after many tries, I have been unable to get this done.
If anyone can help me get the right camera settings, I would be
thankful indeed :-)
Subject: Re: Ortho camera help needed
Date: 6 Apr 2005 10:36:24
Message: <4253f3e8@news.povray.org>
> thankful indeed :-)
  Did you try with a 'rotate' command at the end of the camera block?
Date: 6 Apr 2005 11:55:00
Message: <web.4254061f95e2a3f311f34f480@news.povray.org>
I've been trying just that, unfortunately, it seems I can't find just the
right angle. Also, I made a mistake in the above diagram. One of the middle
lines ought to be removed, as such:
These are my current camera settings:
  orthographic
  location <0,0,1>
  look_at  <0,0,0>
  right 1*x
  up 1*y
  rotate <52, 0, 45>
I've only been rotating the first number, and the closest I got so far
was as the first diagram was, but after I realized my mistake, I kept
changing
the rotation, with no luck.
Date: 10 Apr 2005 10:12:24
Message: <42593448@news.povray.org>
"NullVoid" <nomail@nomail> wrote in
news:web.4254061f95e2a3f311f34f480@news.povray.org:
[snip]
[snip]
> changing
I have no experience with ortho cameras, so don't shoot me if this
doesn't work, but maybe you want to try:
  orthographic
  location <0,1,0>  // change the y value to be higher if you want a
      //picture from farther away
  look_at  <0,0,0>
  right 1*x
  up 1*y
  rotate <0,45,0>
Maybe it works?
Just my two cents.
-Mike C
