POV-Ray : Newsgroups : povray.newusers : Volume and Area Server Time
20 Nov 2025 09:33:12 EST (-0500)
  Volume and Area (Message 1 to 4 of 4)
Subject: Volume and Area
Date: 18 Mar 2005 12:15:00
Message: <web.423b0c5e64a8b38e5f8006bd0@news.povray.org>
Are there any provisions for POVRay to output statistics such as area or
volume of a single object or some other correlated measure?
Thanks.
Subject: Re: Volume and Area
Date: 18 Mar 2005 13:01:51
Message: <14251442.5LNB2etjWF@raf256com>
There was a function that can return if given point is insade an object - it
can be done using Trace. Use it meany times on object bounding box and
calculate hits/misses
Rafal Maj Raf256
Date: 18 Mar 2005 16:22:39
Message: <423b469f@news.povray.org>
  I believe that problem borders the impossible in the general case.
  You can approximate the volume of an object by taking samples, but that's
inaccurate and slow.
Date: 19 Mar 2005 09:32:25
Message: <423c37f9$1@news.povray.org>
kmac99 nous apporta ses lumieres en ce 2005-03-18 12:14:
> Thanks.
For simple shapes like sphere and box, you can do the maths using the dimentions used.
For other
shapes, the formuas are more complex, look in your geometry and trigs school books. If
you used CSGs
operations, isosurfaces, meshes or hightfields, I doubt you can even get a decent
evaluation in most
cases.
