POV-Ray : Newsgroups : povray.newusers : Animation techniques Server Time
21 Jun 2025 18:34:11 EDT (-0400)
  Animation techniques (Message 1 to 4 of 4)
Subject: Animation techniques
Date: 16 Mar 2005 05:10:01
Message: <web.42380518705ea92ff5f6f3660@news.povray.org>
For the first time since I'm using POV-ray I would like to make an
animation. I tried to find information about "general techniques" about how
to do it, without success.
I know about the "clock" parameter and up to now I have tried to define
mathematical functions of this parameter for further use in the script. But
I can assume that this is not the easiest way to realise an animation. The
thing rapidely becomes very complexe, since I want to move different
mechanical parts, changing the color and brightness of some heating
elements, and I also want to visualize some moving smoke...!
Some link to "standard animation techniques" with povray or some suggestions
about how to organize the scipt would help me a lot. Thanks in advance.
REYNALD
Subject: Re: Animation techniques
Date: 16 Mar 2005 07:10:58
Message: <42382252$1@news.povray.org>
Reynald wrote:
> Hi,
> REYNALD
Some things to get you started:
Moving mechanical parts, like robots, etc., is usually done using
Inverse Kinematics:
   - http://en.wikipedia.org/wiki/Inverse_kinematics
Smoke, water, fire etc. are usually done with either a particle system
or a fluid dynamics solver system. There are several particle systems
available for POV-Ray, e.g.
   - Rune's: http://runevision.com/3d/include/particles/
   - Tim Nikias': http://nolights.de/download.html#PartixGen
For animating physically correct models with masses and springs, like
cloth, etc., use a something like Christoph Hormann's SimPOV, which is
included in MegaPOV:
   - http://megapov.inetart.net/index.html
If you want to interpolate smoothly from one state to another, e.g. for
blending from one color to another, you can use POV-Ray's splines:
   - http://povray.org/documentation/view/3.6.1/234/
There are many more include files out there to help you with special
animation tasks, like:
   - Liquid Surface Simulation: http://nolights.de/download.html#LSSM
   - Clock modifier macros:
     http://www.geocities.com/SiliconValley/Lakes/1434/clockmod.html
But after all, the clock variable is your main way to do animations in POV.
I hope those links get you started, feel free to ask if you got more
questions. Also note, that there are special newsgroups for animations:
   - povray.animations: For asking questions about animations
   - povray.binary.animations: For posting animations (< 2MB)
HTH,
Florian
Date: 17 Mar 2005 04:15:00
Message: <web.423949a1e175fd30f5f6f3660@news.povray.org>
Thanks Florian, I will spend a fiew days to look at these links, read as
much as possible... and try some first animations. The clock modifier macro
looks great!
Reynald
Date: 18 Mar 2005 15:35:26
Message: <423b3b8e$1@news.povray.org>
Reynald wrote:
 > Hi,
about how
 > define mathematical functions of this parameter for further use in
 > the script. But I can assume that this is not the easiest way to
 > realise an animation. The thing rapidely becomes very complexe,
 > since I want to move different mechanical parts, changing the
 > color and brightness of some heating elements, and I also want
 > in POV.
When using ClockMod, I would *HIGHLY* recommend that you:
1) Define your objects within a #macro, that takes parameters for the
    characteristics you can't do outside the 'union' or 'object'
    (such as most texture changes, the angle of the fingers on a hand,
     wrist on an arm, arm on a shoulder, etc.).  For example
        #macro Scissors( ang )
           union {
               object { HalfScissors }
               object { HalfScissors rotate <180,ang,0> }
    That's off the top of my head and bogus, but the idea is there:
    For a pair of scissors, there is no way to change the angle of
    the two halves after they are joined, and the macro lets this be
    simple.
2) For complex animations, either use #switch+#case statements for
    the camera locations, change of scenes, etc., or separate POV+INI
    files; the latter is probably easier.
3) Use ClockMod within these top-level POV file to implement the math
    formulas for the parameters to your object macros.
I've not see the ClockMod package for a while, but the old examples had
all the mods embedded in the object itself, and *that* leads to a lot of
tediousness that can be avoided almost entirely by point #1 above.
Comments?
- RP
