POV-Ray : Newsgroups : povray.newusers : Need help with a povray command... Server Time
20 Mar 2026 17:31:38 EDT (-0400)
  Need help with a povray command... (Message 1 to 5 of 5)
Subject: Need help with a povray command...
Date: 26 Feb 2005 14:30:01
Message: <web.4220cd21b888af1ba604cfa70@news.povray.org>
#!/bin/perl
$width=1024;
$height=768;
$slice=192;
$k=$height/$slice; # Must be an integer, no check done
for ($i = 0 ; $i < $k; $i++ ) {
 $start = $i * $slice+1;
 $end =  ($i +1 ) * $slice;
 $text = sprintf ("/Users/myuser/desktop/test/linux.pov +Linclude/ +FP
+H$height +W$width -D +SR%d +ER%d +0linux_%0.4d.ppm",$start,$end,$i) ;
 print `echo "$text" > $i.ini`;
This little script should split a povray file into a bunch of little pieces
(ppm's), but I'm having problems with this line right here:
("/Users/myuser/desktop/test/linux.pov +Linclude/ +FP +H$height +W$width -D
It first converts my pov file into a series of 4 ini files. Each of these
ini files will create a ppm file from a certain point in the image to
another point. I recieve this error on trying to render:
Scene File Parser Initialization Error: Reading from
'/Users/Optio/Desktop/testi
ng/linux.pov' is not permitted.  Check the configuration in
'/Users/optio/.povra
y/3.6/povray.conf'.
Any ideas???
Subject: Re: Need help with a povray command...
Date: 26 Feb 2005 19:08:35
Message: <42210f83@news.povray.org>
> y/3.6/povray.conf'.
> Any ideas???
Reading not permitted ? Looks like you run it on a unix/linux system.
Have you checked read permissions of files ? Same result after a chmod 777 ?
Date: 27 Feb 2005 03:00:02
Message: <cvruiu$2or$1@chho.imagico.de>
>> y/3.6/povray.conf'.
>> Any ideas???
Please don't try to answer if you don't know the answer.
He should do exactly what he is told to do, namely check his povray.conf.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 27 Feb 2005 13:55:01
Message: <web.4222166730a72b04da6dd1c90@news.povray.org>
> >> y/3.6/povray.conf'.
> >> Any ideas???
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
> Last updated 23 Sep. 2004 _____.//^>_*_<^/.______
Well I don't even know what I would be looking for in my povray .conf as I
can "povray linux.pov" and it runs just fine so this must be a problem with
the .ini files
Once the script runs the output to the first of my ini files is as follows:
+I/Users/Optio/Desktop/testing/linux.pov +Linclude/ +FP +H768 +W1024 -D +SR1
+ER192 +Olinux_0000.ppm
Now I have tried chmod 777 on my linux.pov and I now get a different error
message:
Possible Scene File Parser Initialization Error: Could not find file
 'Users/Optio/Desktop/testing/linux.pov'
Scene File Parser Initialization Error: Cannot open input file.
So now I'm assuming that there is something wrong with the format of my ini
file.
Date: 27 Feb 2005 14:45:00
Message: <web.4222221930a72b048ca6c07d0@news.povray.org>
"Stuart" <stu### [at] obelixca> wrote:
> Any ideas???
Please read <http://www.povray.org/documentation/view/3.6.1/794/>
