POV-Ray : Newsgroups : povray.newusers : Empty filename Server Time
13 Oct 2025 21:07:48 EDT (-0400)
  Empty filename (Message 1 to 2 of 2)
Subject: Empty filename
Date: 23 Feb 2005 15:20:01
Message: <web.421ce4e1e64be003e2dc97b80@news.povray.org>
I have just installed POVRAY to use with ldraw and the L3PAO add on.  When I
run L3P via the add on, POV RAY opens but I get the message "Empty filename
after /RENDER"
What have I done wrong?
Subject: Re: Empty filename
Date: 24 Feb 2005 03:24:38
Message: <421d8f46@news.povray.org>
"andrewa" <and### [at] comcastnet> wrote in message
news:web.421ce4e1e64be003e2dc97b80@news.povray.org...
>I
> filename
> after /RENDER"
Don't know but I searched for info on this and looks like someone has said
it doesn't work directly with version 3.5 or 3.6:
http://www.ldraw.org/modules.php?op=modload&name=News&file=article&sid=105
Installation procedures or LDraw seems to indicate it must be done in
conjunction with POV-Ray (again, I don't know about L3PAO), as seen here:
http://www.ldraw.org/modules.php?op=modload&name=News&file=article&sid=104
Empty filename error means none was given on the commandline, so something
is amiss about the utility sending it.
I'd suggest contacting the author of the utility.
Bob Hughes
