POV-Ray : Newsgroups : povray.newusers : image masks? Server Time
19 Aug 2025 18:30:44 EDT (-0400)
  image masks? (Message 1 to 3 of 3)
Subject: image masks?
Date: 14 Feb 2005 01:55:01
Message: <web.42104a269bbb316bdfffe15f0@news.povray.org>
So I have an image that I want to mask onto a surface to make only part of
it reflective (it's a logo).  I can place the image map on the surface and
get the excess transparent but when I apply the finish, the transparent
part picks this up as well so I get specular where I don't want them.
Anyone know how to fix/get around this?
Subject: Re: image masks?
Date: 14 Feb 2005 02:53:48
Message: <4210590c$1@news.povray.org>
<Mienai> wrote in message
news:web.42104a269bbb316bdfffe15f0@news.povray.org...
'material_map' might be all you need, so give that a lookup in the doc/help.
Bob Hughes
Date: 14 Feb 2005 09:00:02
Message: <4210aee2@news.povray.org>
Not quite sure what you have and havenot done but it reads like you need
to have your desired finish parallel your transparency?
ie
#declare T_Logo =    //not transparent
	pigment { ...some colour... transmit 0 }
	finish { .... reflection 1 }
#declare T_Ground =   //transparent
	pigment { rgb 1 transmit 1 }
	finish { reflection 0 diffuse 0 specular 0 }
object {
	...object...
		image_pattern {
			sys "logo.bmp"
			texture_map {
				[0 texture { T_Logo }]
				[1 texture { T_Ground }]
Or maybe I am not understanding the problem?
