POV-Ray : Newsgroups : povray.newusers : How to pass variables from one frame to the next Server Time
30 Sep 2024 04:16:27 EDT (-0400)
  How to pass variables from one frame to the next (Message 1 to 5 of 5)
Subject: How to pass variables from one frame to the next
Date: 10 Feb 2005 07:30:00
Message: <web.420b52fd9cf29933a278c9190@news.povray.org>
I'm making an animation of several frames. I would like to be able pass a
variable from one frame to the next. Is there any way of doing this?
In advance thanx
Georg Olesen
Subject: Re: How to pass variables from one frame to the next
Date: 10 Feb 2005 08:18:46
Message: <420b5f36$1@news.povray.org>
AFAIK, you can do that with MegaPOV, but don't quote me on that, I don't use
MegaPOV.
You could also have a look at my I/O-Macros to save a variable to disc and
load it in the next frame... http://www.nolights.de/download.html#IO-Macros
Or you could write your own macros to do that.
Tim
"Tim Nikias v2.0"
Date: 10 Feb 2005 09:50:19
Message: <Qw9nDGAAQ3CCFwSV@econym.demon.co.uk>
>MegaPOV.
Such a facility was in MegaPov 0.* but didn't get carried over to
MegaPov 1.* when the whole thing got rewritten using the POV 3.5 source.
Mike Williams
Gentleman of Leisure
Date: 9 Apr 2005 22:52:12
Message: <425894dc@news.povray.org>
"Georg Olesen" <vib### [at] hotmailcom> wrote in
news:web.420b52fd9cf29933a278c9190@news.povray.org:
> pass a variable from one frame to the next. Is there any way of doing
> this? In advance thanx Georg Olesen
How are you defining the variables in frame 1 vs, e.g., frame 2, 5, or
50?
IIRC, randomly generated numbers will generate the same numbers in
sequence every time the frame is rendered, so you can just use the clock
variable * difference and tack that onto the original variable.  Right?
To get a variable, you'd usually declare like #declare
valuea=macro(paramforframea); so you'd be able to move them between
frames by recalculating the calculation from the last frame, so in frame
b, you'd be able to get the thing in frame a by doing the same thing
again, right?
Otherwise, I have no idea what you're trying to achieve.  And I'm not
even sure about this myself, it's just a guess.
Date: 11 Apr 2005 14:26:08
Message: <425AC14D.9060300@wanadoo.fr>
In fact the solution depends on what type of variable you need.
If it's evolution is dependant on the frame number, you can use the
"clock" variable (e.g : rotate clock*360*x for a complete rotation
around x-axis in the entire animation).
If your variable is predictable for each frame, i.e you know how to
compute it for each single frame, you can do so. Initiating a
random-numbers stream and taking as many of them as the frame number
gives you a "coherent" situation (as long as random numbers can be
qualified that way) throughout the animation.
If you cannot know what was your variable's value on the frame before,
then you can use a temporary file : write the variable in the file at
the end of the script, read the variable from the file at the beginning.
On first frame, initialise with whatever you need.
Does one of these methods match your need ?
Regis.
