POV-Ray : Newsgroups : povray.newusers : How do I Perform Transformations on Isosurface, like Scale, Shear, Rotate e= Server Time
20 Aug 2025 01:33:56 EDT (-0400)
  How do I Perform Transformations on Isosurface, like Scale, Shear, Rotate e= (Message 1 to 3 of 3)
Subject: How do I Perform Transformations on Isosurface, like Scale, Shear, Rotate e=
Date: 21 Jan 2005 23:00:00
Message: <web.41f1cf252775d07b3d54f5180@news.povray.org>
etc?
How do I modify the code?
Subject: Re: How do I Perform Transformations on Isosurface, like Scale, Shear, Rotate e=
Date: 22 Jan 2005 01:25:05
Message: <FYripHAgFf8BFwO2@econym.demon.co.uk>
>etc?
The "scale" and "rotate" keywords work perfectly well for isosurfaces.
To shear an isosurface you can perform variable substitution.
See <http://www.econym.demon.co.uk/isotut/substitute.htm> for the
principles involved.
Here's a sheared box. I'm using a box because it's easy to see the
effect of the shear, scale and rotation. Just replace F with the
function of your isosurface.
#declare F=function{max((y*y-1),(x*x-1),(z*z-1))}
isosurface {
  function { F(x-y/3,y,z) }
        max_gradient 3
        contained_by{sphere{0,2}}
        pigment {rgb 1}
You can perform scaling and rotation by substituting the variables, but
you will usually need to adjust the size of the contained_by object and
max_gradient, which is unnecessary when you use the "scale" and "rotate"
keywords.
Here's a scaled box:
#declare XScale=2;
#declare YScale=1;
#declare ZScale=0.5;
isosurface {
  function { F(x/XScale, y/YScale, z/ZScale) }
        max_gradient 14
        contained_by{sphere{0,3}}
        pigment {rgb 1}
Here's a box rotated by 30 degrees about the y axis.
#declare A=radians(30);
isosurface {
  function { F(x*cos(A)-z*sin(A), y, z*cos(A)+x*sin(A)) }
        max_gradient 4
        pigment {rgb 1}
Mike Williams
Gentleman of Leisure
Date: 3 Feb 2005 12:50:54
Message: <Ix2xzAAlJmACFwxg@econym.demon.co.uk>
>etc?
I suddenly had a thought about how to do all these by variable
substitution, and have written it up in my isosurface tutorial.
<http://www.econym.demon.co.uk/isotut/substitute.htm#shear>
Mike Williams
