POV-Ray : Newsgroups : povray.newusers : making object completly transparent but with contour frame on Server Time
30 Sep 2024 04:14:21 EDT (-0400)
  making object completly transparent but with contour frame on (Message 1 to 3 of 3)
Subject: making object completly transparent but with contour frame on
Date: 12 Jan 2005 10:35:00
Message: <web.41e5426f83373c9ae76370fa0@news.povray.org>
Hi All,
I want to make a ellipsoid (but it the same question for any object)
completly transparent but still having the contour in plain whatever
colour.
example, for a box, it would be easy to, instead of ploting a box, ploting
thin cylinders that would represent the box frame.
But, what about an ellipsoid ? I make ellipsoid by plotting a sphere and
scaling it by the command scale<0,0,A> which will scale the object in the
direction z by A. It's easy to make it more or less transparent but I don't
know how to keep the frame (if it's possible)
Thanks in advance for your help.
David from Sheffield (England)
Subject: Re: making object completly transparent but with contour frame on
Date: 13 Jan 2005 02:31:01
Message: <Xns95DD56A3B66B8jgrimbertmeandmyself@203.29.75.35>
> Hi All,
> colour.
> ploting thin cylinders that would represent the box frame.
> and scaling it by the command scale<0,0,A> which will scale the object
> in the direction z by A. It's easy to make it more or less transparent
> but I don't know how to keep the frame (if it's possible)
A pattern like AOI (angle of incidence) should provide you with what you
need. You just need to move to Megapov.
l'habillement, les chaussures que le maquillage et les accessoires.
Date: 13 Jan 2005 04:46:44
Message: <41e64384@news.povray.org>
If, however, the object doesn't have to look "outlined" in reflections, you
may just go with the slope-pattern of the official POV-Ray.
"Tim Nikias v2.0"
