POV-Ray : Newsgroups : povray.newusers : fine tuning media (too many shadows...) Server Time
10 Apr 2026 12:27:06 EDT (-0400)
  fine tuning media (too many shadows...) (Message 1 to 5 of 5)
Subject: fine tuning media (too many shadows...)
Date: 15 Dec 2004 06:00:00
Message: <web.41c018783f331b0b854699050@news.povray.org>
how can i reduce the instance of "repeated shadows" in the media for this
render?  there are 4 spotlights in each of the corners of the xmas box.
binary is hosted at :
http://users.eastlink.ca/~lebla312/noel2004x800.bmp
i can post the pov file later if necessary
Subject: Re: fine tuning media (too many shadows...)
Date: 15 Dec 2004 06:11:29
Message: <41c01be1@news.povray.org>
Just increase the 'samples' value in your 'media' block.
  Fine-tuning aa_threshold and aa_level might also help (at least to
get a better result with a bit faster render).
Date: 15 Dec 2004 09:20:01
Message: <web.41c047ac7ff329aa854699050@news.povray.org>
thank you very much for the prompt reply.
did you have a chance to peek at the render?
i always thought that `samples` variable would come into play some day.
what are average/useful settings?  do i start with min 10 and max 1000 or
just experiment/tweak until iget the results i need?  i am asking this
since i reaaly should be working and not running renders in my head and
asking silly questions to the community.
"soon he will have a gallery posted somewhere to show you all the fun he's
had with PovRay/Moray"  <~~~~~ optimistic fan
Date: 15 Dec 2004 09:37:30
Message: <41c04c2a@news.povray.org>
  Since proper settings depend on almost everything in your scene, getting
good values is usually a question of trying until you find them.
  The default values of media give acceptable results for a wide range of
scenes, but in many cases happens as with your image. In that case you
just need to fine-tune them. Your case seems quite clearly a too low
samples value, so pumping it up should help (of course it will probably
make rendering slower, but there's always a price to pay for more
accuracy).
Date: 15 Dec 2004 10:35:00
Message: <web.41c058ba7ff329aa854699050@news.povray.org>
thanks again,
will post results soon.  will post more questions.  will lose sleep.  ;-)
> accuracy).
