POV-Ray : Newsgroups : povray.newusers : isosurface problem Server Time
20 Aug 2025 01:35:00 EDT (-0400)
  isosurface problem (Message 1 to 3 of 3)
Subject: isosurface problem
Date: 8 Dec 2004 04:10:00
Message: <web.41b6c45f92ff4ee0222789b40@news.povray.org>
Hopefully someone can help or tell me why what's happening is.  I've taken
one isosurface object and CSG'd it with another to produce a tube-like
object.  Unfortunately the inner surface of the tube isn't visible and
makes anypart of the tube behind the inner part (from the camera's angle)
transparent.  Anyone know what's going on?  Here's my code with the object
cross-sectioned so you can see what I'm talking about.
#declare R1=3;
#declare tor1=
isosurface{
function{sqrt(pow(sqrt(pow(x,2)+pow(z,2))-R1,2)+pow(y,2))-(atan(x/(abs(z)+.0000001))/pi+1)}
  contained_by{sphere{<0,0,0>,5}}
#declare tor2=
isosurface{
function{sqrt(pow(sqrt(pow(x,2)+pow(z,2))-R1,2)+pow(y,2))-(atan(x/(abs(z)+.0000001))/pi+.8)}
  inverse
intersection{
  object{tor1 pigment{Green}}
  object{tor2}
  plane{y,0}
  pigment{Red}
Subject: Re: isosurface problem
Date: 8 Dec 2004 05:35:00
Message: <web.41b6d83a758552435e1e98150@news.povray.org>
By default only the first surface is found, so for transparent or CSG'ed
isosurfaces you put the keyword 'all_intersections' in the isosurface
definitions.
Hope this helps,
Mike Andrews.
> #declare R1=3;
> #declare tor1=
> isosurface{
> #declare tor2=
> isosurface{
>   inverse
> intersection{
>   object{tor2}
>   plane{y,0}
>   pigment{Red}
Date: 8 Dec 2004 17:15:00
Message: <web.41b77ba8758552435df24d3f0@news.povray.org>
> definitions.
> Hope this helps,
> Mike Andrews.
Thanks, that fixed what my problem was.  Onto the next...
