POV-Ray : Newsgroups : povray.newusers : Re: Can't get glass to look right Server Time
20 Mar 2026 21:07:14 EDT (-0400)
  Re: Can't get glass to look right (Message 1 to 3 of 3)
Subject: Re: Can't get glass to look right
Date: 26 Nov 2004 16:35:00
Message: <web.41a7a0161bf351e2290632e60@news.povray.org>
MAX TRACE LEVEL is the key!
Cheap explanation:
Pov returns a black color for every ray that DOES NOT hit some solid object
after it bounces around max_trace_level number of times (eg 5 times) and
THAT is why the ball is opaque. Jaime Vives Piqueres has a file called
"glasswater.pov" on the "Persistance of Ignorance" site www.ignorancia.org
and that helped me immensely.
It's default is 5
Set it to something insanely high like 64 and you'll be laughing!
Check it out:
#version 3.6;
global_settings{assumed_gamma 1.8 max_trace_level 64}
#include "textures.inc"
#include "glass.inc"
#include "metals.inc"
#include "golds.inc"
#include "stones.inc"
#include "woods.inc"
#include "shapes.inc"
#include "shapes2.inc"
#include "functions.inc"
#include "math.inc"
#include "transforms.inc"
#declare r=10;
#declare rot=<50,-10,0>;
camera
 angle 40
 location<0,0,-r>
 rotate rot
 look_at<0,1.8,0>
 right (image_width/image_height)*x
//light_source{<15,25,-25> rgb 1 area_light 3*x 3*z 4 4}
light_source{<15,25,-25> rgb 1}
plane
 y 0
 pigment
  //rgb 1
  checker rgb 1 rgb 0
#declare tex=texture{pigment{rgb<1,0,0>}finish{specular 0.8 roughness 0.07
reflection 0.3}}
merge
 difference
  cone{<0,0,0>0.8<0,1,0>0.3}
  cone{<0,-0.01,0>0.7<0,1.01,0>0.2}
 torus{0.75 0.05 clipped_by{plane{y 0}}}
 lathe
  cubic_spline
  5 <1.0,-0.3> <0.3,0><0.2,0.8><0.3,1.5> <0.5,2>
  translate<0,1,0>
 merge
  difference
   sphere{0 1}
   sphere{0 0.9}
   plane{-y 0}
  torus{0.95 0.05}
  difference
   sphere{0 0.9001}
   plane{-y,0.25}
   material{texture{pigment{rgbf<1,0.6,0,0.9>}finish{ambient 3 reflection
0.2}}interior{ior 1.3}}
  scale<1,1.6,1>
  translate<0,4,0>
 //texture{tex}
 material
  texture{pigment{rgbf<1,1,1,0.9>}finish{specular 1 roughness 0.03}}
  interior{ior 1.5}
 translate<0,0.05,0>
Just cut and paste and THEN make sense of it.
Captain
Date: 26 Nov 2004 17:04:06
Message: <41a7a856@news.povray.org>
Not sure if it's the thingh that you want...
The code is:
#version 3.6;
global_settings{assumed_gamma 1.5 max_trace_level 10}
#include "math.inc"
#declare r=10;
camera
 angle 40
 location<0,0,-r>
 rotate rot
 look_at<0,1.8,0>
plane
 y 0
 pigment
  //rgb 1
  checker rgb 1 rgb 0
#declare tex=texture{pigment{rgb<1,0,0>}finish{specular 0.8 roughness 0.02
reflection 0.1}}
merge
 difference
 lathe
  cubic_spline
  translate<0,1,0>
 merge
  difference
   sphere{0 1}
   sphere{0 0.9}
   plane{-y 0}
  torus{0.95 0.05}
  difference
   sphere{0 0.9001}
   plane{-y,0.25}
  scale<1,1.6,1>
  translate<0,4,0>
 //texture{tex}
 material
  texture{pigment{rgbf<1,1,1,0.9>}finish{specular 0.2 roughness 0.03}}
  interior{ior 1.3 }
 translate<0,0.05,0>
Now is transparent and you can see the checker through the glass.
Best regards,
Oleguer
news:web.41a7a0161bf351e2290632e60@news.povray.org...
> Cheap explanation:
object
> It's default is 5
> Check it out:
> #version 3.6;
> #include "math.inc"
> #declare r=10;
> camera
>  angle 40
>  location<0,0,-r>
>  rotate rot
>  look_at<0,1.8,0>
> plane
>  y 0
>  pigment
>   //rgb 1
>   checker rgb 1 rgb 0
> reflection 0.3}}
> merge
>  difference
>  lathe
>   cubic_spline
>   translate<0,1,0>
>  merge
>   difference
>    sphere{0 1}
>    sphere{0 0.9}
>    plane{-y 0}
>   torus{0.95 0.05}
>   difference
>    sphere{0 0.9001}
>    plane{-y,0.25}
>   scale<1,1.6,1>
>   translate<0,4,0>
>  //texture{tex}
>  material
>   interior{ior 1.5}
>  translate<0,0.05,0>
> Captain
Date: 27 Nov 2004 08:34:11
Message: <41a88253@news.povray.org>
  Well, the questions and tips in the documentation would have told
you the same thing...
