POV-Ray : Newsgroups : povray.newusers : newbie 3D arrows and ornate picture frames Server Time
17 Jan 2026 13:07:07 EST (-0500)
  newbie 3D arrows and ornate picture frames (Message 1 to 2 of 2)
Subject: newbie 3D arrows and ornate picture frames
Date: 30 Oct 2004 04:25:00
Message: <web.41834eb249fa51a78b7cb52f0@news.povray.org>
my first post .. I am keen on povray because I can, potentially at least,
program what I want .
I have two things I want to accomplish
* 3D arrows, bent and wobbly and "cute". With a bit of "character". I
thought maybe I could try Chris Colefax's bender, but I can't even get a
basic arrow going . should I start with a cone for the head and a cylinder
for the shaft? how about different "slopes" on the base of the cone and the
side?
Some starter code would be nice .. I am having trouble visualizing/guessing
the function calls I need, let alone the appropriate arguments (size and
location etc)
* ornate picture frames, like you might see in an art gallery. I got as far
as thinking one might make some basic material with a routed or molded
profile, and then cut it at 45 degree angles and fold it - just like you
would do if you were woodworking - but I have not the foggiest notion of
how to write this code.
Again, if someone can help me here .. I think I can probably make progress
on my own once I get a basic framework.
thankyou
Subject: Re: newbie 3D arrows and ornate picture frames
Date: 30 Oct 2004 05:30:26
Message: <Xns9592750EB71CBseed7@news.povray.org>
> least, program what I want .
Welcome!
There are many ways to achieve this. You can "draw the outlines" and use
the prism to extrude the arrow. Or use the 'spheresweep' object in
combination with a cone. Or use blobs and splines to build an arrow.
Thinking of blobs, you could use arrows found in ttf fonts and process
them with Remko de Korte's Softtext http://www.xs4all.nl/
~remcodek/softtext.html  Then, with some macros you can bend the arrow
any way you want.
> as far as thinking one might make some basic material with a routed
> or molded profile, and then cut it at 45 degree angles and fold it
Again, use the 'prism' object to extrude the profile you want. Then cut
off the ends using a difference and boxes.
Ingo
