POV-Ray : Newsgroups : povray.newusers : DNA creation help? Server Time
22 Dec 2025 02:05:11 EST (-0500)
  DNA creation help? (Message 1 to 10 of 17)
Subject: DNA creation help?
Date: 23 Oct 2004 22:30:00
Message: <web.417b13026e9252d7505508630@news.povray.org>
I've been trying to create a strand of DNA using an isosurface. However, I
keep having trouble creating the double helix using the function f_helix1
found in functions.inc
Could anybody give me an example double helix for me to start with? It'd be
a big help.
Subject: Re: DNA creation help?
Date: 24 Oct 2004 05:08:03
Message: <417b70f3@news.povray.org>
Maybe it will be usefull:
#declare Helice = union      {
 #declare myCount = 0;
#while(myCount < 50)
 object  {
 Your_Object
  translate <0,myCount/1.2,0>
  rotate <0,myCount*9.5,0>
#declare myCount = myCount + 1;
#end  };
object  { Helice }
object  { Helice rotate <0,90,0> translate <150, -60, 0>}
Best regards,
Oleguer
news:web.417b13026e9252d7505508630@news.povray.org...
be
> a big help.
Date: 24 Oct 2004 11:46:59
Message: <417bce73$1@news.povray.org>
Why it doesn't work?
#include "functions.inc"
  location  <7, 25, -20>
  look_at   <5, 3.0,  0.0> }
light_source { <-100,200,-100> colour rgb 1 }
background { White }
isosurface {
function {  f_helix1 (1, 1, 1, 2, 3, 4, 5, 0.1, 1, 25) }
        max_gradient 1.5
        contained_by {sphere {0, 1.2} }
        pigment {rgb .9}
Oleguer
Date: 24 Oct 2004 12:15:00
Message: <web.417bd46e89e84e748345dda10@news.povray.org>
For some reason, all of my efforts, along with both of your ideas, result in
blank screens; black for me, white for 0leguer's code. I have made sure to
include all necessary .inc files...I don't understand why it won't show up.
Date: 24 Oct 2004 12:36:21
Message: <417bda05$1@news.povray.org>
Yes because you have to put your object, cylinders for exemple:
#include "textures.inc"
  background { color White }
  camera {location <170, 11, -110>look_at  <180, -15, -16>}
  light_source { <170, -30, -100> color White}
#declare cilindros = union     {
cylinder{ <-2,0,0>, <2,0,0>, .15
texture { pigment { White } finish { phong .5 } rotate y*90 }}
object  { cilindros
rotate <0,myCount*9.5,0> }
object  { Helice }
object  { Helice rotate <0,90,0> translate <150, -60, 0> }
Tray with it, this is an exemple, here you can see the four nitrogenous
bases if you put an sphere in the two sides of the cylinders on the axis
x, -x.
I had never used the "functions.inc" I don't know why I can not see the
double helix with the functions, I'm investigating it.
Oleguer
news:web.417bd46e89e84e748345dda10@news.povray.org...
in
up.
Date: 24 Oct 2004 20:29:35
Message: <Qi4HXDAlR1eBFw$n@econym.demon.co.uk>
>a big help.
http://www.econym.demon.co.uk/isotut/builtin1.htm#helix1
The significant numbers for obtaining a double helix are the first
parameter after the x,y,z being 2 and the third parameter (minor radius)
being less than the fourth (major radius)
Mike Williams
Gentleman of Leisure
Date: 24 Oct 2004 20:48:48
Message: <1Dqe$HAo1EfBFwh0@econym.demon.co.uk>
>camera {
>isosurface {
>        max_gradient 1.5
>        pigment {rgb .9}
The main reason is that you're only evaluating a single point of the
function. You should say "f_helix1 (x,y,z..." not "f_helix1 (1,1,1..."
You'll also need to increase your max_gradient to about 6.
Mike Williams
Date: 25 Oct 2004 02:32:37
Message: <417c9e05$1@news.povray.org>
Yes Mike, Ok, now that's right.
isosurface {
function {  f_helix1 (x, y, z, 2, 3, 4, 5, 0.1, 1, 25) }
        max_gradient 6
        pigment {rgb .9}
Thank you very much,
Oleguer
news:1Dqe$HAo1EfBFwh0@econym.demon.co.uk...
> >camera {
> >isosurface {
> >        max_gradient 1.5
> >        pigment {rgb .9}
> Mike Williams
Date: 25 Oct 2004 16:50:41
Message: <417d6721@news.povray.org>
How can I rotate it? and how can I translate it? Of I do this it gives me an
error:
isosurface {
function {  f_helix1 (x, y, z, 2, 3, 4, 5, 0.1, 1, 25) rotate x*25 }
        max_gradient 6
        pigment {rgb .9}
Many thanks,
Oleguer
news:417c9e05$1@news.povray.org...
> isosurface {
>         max_gradient 6
>         pigment {rgb .9}
> Oleguer
> > >camera {
> > >isosurface {
> > >        max_gradient 1.5
> > >        pigment {rgb .9}
> > Mike Williams
Date: 25 Oct 2004 22:47:32
Message: <qMfpsGA9qbfBFwzl@econym.demon.co.uk>
>error:
>isosurface {
>        max_gradient 6
>        pigment {rgb .9}
Rotate the isosurface, not the function
isosurface {
        max_gradient 6
        rotate x*25
        pigment {rgb .9}
Mike Williams
