POV-Ray : Newsgroups : povray.newusers : Steering a vehicle Server Time
20 Mar 2026 23:01:45 EDT (-0400)
  Steering a vehicle (Message 1 to 1 of 1)
Subject: Steering a vehicle
Date: 17 Oct 2004 09:15:00
Message: <web.41726f1a7d9a2878ed9ef17e0@news.povray.org>
Just thought I'd share this with some of you folk, I spent ages trying to
get this to work and finally cracked it. After you defince your vehicle,
with wheels that roll, that was tricky too, you are left with the task of
steering the fronts, this is it.
frames - no. of frames in sequence
trackpoints - no of points used to define the track
trackspline - self explanatory
note, steering has to be declared as 0 if the two vectors are parallel
_______________________________________________________
#declare dleng = vlength( trackspline(clock*trackpoints) -
trackspline((clock+1/frames)*trackpoints) );
#declare dir1 = trackspline((clock-1/frames)*trackpoints) -
trackspline(clock*trackpoints);
#declare dir2 = trackspline(clock*trackpoints) -
trackspline((clock+1/frames)*trackpoints);
#declare rotat = VRotation(dir1,dir2,y);
#if(rotat=0)
    #declare steering=0;
  #else
    #declare hdist = dleng/(sin(rotat));
    #declare tradi = sqrt(pow(hdist,2)-pow(dleng,2));
    #declare steering = degrees(atan(base/(tradi*sgn(rotat))));
script uses trig to find the angle between two vectors, you then use this
angle with the cars wheelbase (base) to find the radius of turn (tradi)
final output is steering
Odometer script
#declare distrav = vlength( trackspline((clock+1/frames)*trackpoints) -
trackspline(clock*trackpoints) );
#declare speed=distrav*framerate;
#declare J = 0;
#while (J<=(clock*frames))
   #if (J=0)
      #declare odometer=0;
   #declare Point1 = trackspline(J/frames*trackpoints);
   #declare Point2 = trackspline((J+1)/frames*trackpoints);
   #declare ddist = vlength( Point2 - Point1 );
   #declare odometer = odometer + ddist;
   #declare J = J + 1;
#declare tyrerotations=odometer/(2*pi*tyreradius);
multiply tyre rotations to get final angle of wheel as input into the frame
Hope this is useful
