POV-Ray : Newsgroups : povray.newusers : seed and rand Server Time
20 Mar 2026 23:01:21 EDT (-0400)
  seed and rand (Message 1 to 7 of 7)
Subject: seed and rand
Date: 9 Oct 2004 13:05:00
Message: <web.416819786f2b8ebe68d83220@news.povray.org>
Hi.
By the documentation, I understood that the seed function initializes a
stream of random numbers, which is independant with others.
Obviously, it is not true :
I have a scene in which I place objects randomly.
In my scene I first have declarations, then positionning.
So I have 3 seed() functions at the beginning of the code, and I use the
third one at the end. The problem : changing the number specified in the
seed function changes nothing. Using the debug function showed me that the
random numbers are strictly identical whatever seed I use.
Now if I move the seed statement and put it just before the rand function is
used, I have something completely different.
Conclusion : the seed/rand functions are intimately connected, and the use
of one stream visibly "corrupts" the others.
Can anyone tell me why I have not the same result when I put the seed in the
beginning of the code or just before using the stream ?
Subject: Re: seed and rand
Date: 9 Oct 2004 13:20:53
Message: <41681df5$1@news.povray.org>
the
The fact that you consider *not* putting the seed before the calls to rand()
makes me think you're using it wrong. I have never experienced the behavior
you're describing.
Are you doing it like this?
#declare mySeed = seed(123);
#declare randomNumber = rand(mySeed);
The important thing here is that you pass the seed variable into the rand
function.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 9 Oct 2004 15:53:22
Message: <416841b2@news.povray.org>
  Wrong conclusion, but it's impossible to explain why without seeing
your code.
Date: 9 Oct 2004 16:35:01
Message: <web.41684a61124fa141ed8cdc490@news.povray.org>
> function.
>  - Slime
I do use it like this. The behaviour I've seen is that if I have :
#declare Rnd=seed(0);
#declare Rnd1=seed(1)
....much code here using Rnd...
#declare x=rand(Rnd1)
i get an x that is equal to a fixed value whatever I pass as a parameter if
the second seed() statement.
If I move it just before I use it, it works fine. That is what I don't
understand, because I thought that random number streams were totally
independant.
Any idea ?
Date: 9 Oct 2004 19:21:02
Message: <4168725e@news.povray.org>
I tested with this code and it seems to behave as advertised:
#declare Rnd1=seed(1);
#local i=0;#while(i<10)
         #debug #concat ( "\n Rnd: ", str( rand(Rnd),3,6 ) )
         #debug #concat ( "   Rnd2: ", str( rand(Rnd1),3,6 ) )
#local i=i+1;#end
#debug #concat ( "\n\n"   )
#declare Rnd=seed(0); //reset one of the seeds
#local i=i+1;#end
#declare Rnd1=seed(1);  //both seeds
#local i=i+1;#end
#debug #concat ( "\n"   )
         #debug #concat ( "\n Rnd2: ", str( rand(Rnd1),3,6 ) )
#local i=i+1;#end
Date: 11 Oct 2004 02:17:18
Message: <416a256e@news.povray.org>
regdo wrote:
> Hi.
the seed is a number to change the contents of the the random number
sequence.
calling rand gets the next number in the sequence
hence for testing and repeatability of the sequence you use
rand(a_number) eg rand(0) will always the same sequence of numbers
stephen
Date: 14 Oct 2004 19:24:42
Message: <cjameshuff-E5889F.19242214102004@news.povray.org>
In article <web.41684a61124fa141ed8cdc490@news.povray.org>,
> independant.
You are doing something wrong, either with the streams or with the
random numbers, or with your interpretation of the results. The rand()
and seed() functions do operate as the documentation describes, and
multiple streams work just fine. I often use multiple independent
streams when using several randomly generated objects in a scene...you
can change one to use a different seed, and get a different randomly
generated object, without affecting the others. It's especially useful
in plant generators where not all seeds produce a good looking result.
http://tag.povray.org/
