POV-Ray : Newsgroups : povray.newusers : determining location of an object that has been transformed and rotated Server Time
20 Aug 2025 15:57:44 EDT (-0400)
  determining location of an object that has been transformed and rotated (Message 1 to 5 of 5)
Subject: determining location of an object that has been transformed and rotated
Date: 15 Sep 2004 15:55:01
Message: <web.41489cc265a1a06956b76d0d0@news.povray.org>
I have been hunting around for an answer to this (looking at everything from
vector() to spherical geometry pages), and at this point I am looking in
too many directions at once.   Some guidance would be appreciated.
// Lets say there is a vector
// (could be anything)
#declare SomeVector = <10, 20, 30>
// ..  and an object ...
sphere {
     0, 1
// and I translate it away from the origin
translate z*10
// then I rotate it
rotate SomeVector
Where is the center of the sphere after the transformations in <x,y,z>
coordinates?
Now, if I only rotate it by  <10, 20> I think I can figure it out with trig.
 However using all three has me slightly baffled.  I have been digging thru
math.inc, functions.inc, and transforms.inc, and haven't found a funtion to
do this.
And ffor the double whammy, what if I translate and rotate an object an
arbitrary number of times.  How to locate it?
Background:  I have been using povray for a long time, but never intensely.
Thanks - Jeremiah
Subject: Re: determining location of an object that has been transformed and rotated
Date: 15 Sep 2004 16:13:24
Message: <4148a264$1@news.povray.org>
> coordinates?
I'd like to answer that question in two ways. First in a high pitched voice,
and then in my regular voice. Heh, no but seriously; first I'll give you the
answer you were probably looking for, and then I'll tell you the more
practical trick to do what you want in POV-Ray.
Every translation corresponds to adding to the vector:
#declare spherepos = <0,0,0>;
sphere {spherepos, 1
translate <1,2,3>
#declare spherepos = spherepos + <1,2,3>;
Every scale corresponds to multiplying the vector:
scale <4,5,6>
#declare spherepos = spherepos * <4,5,6>;
Rotations are, as you've noticed, a bit more complicated. First, they can be
split into separate rotations around the x, y, and z axes:
rotate <3,4,5>
is equivalent to
rotate <3,0,0>
rotate <0,4,0>
rotate <0,0,5>
Rotating a vector around an axis can be done with the rotation formula. The
best explanation you'll find of this will probably be in a trigonometry
book, but what it comes down to is:
(to rotate in 2 dimensions)
x' = x cos(theta) - y sin(theta)
y' = y cos(theta) + x sin(theta)
So for example
rotate <3,0,0>
can be mimicked by
    <spherepos.x,
     spherepos.y*cos(radians(3)) - spherepos.z*sin(radians(3)),
     spherepos.z*cos(radians(3)) + spherepos.y*sin(radians(3))>;
This is untested code so it's very possible I got something wrong. However,
let me give you the better solution for use in POV-Ray:
#include "transforms.inc"
#declare spheretransform = transform {
translate <1,2,3>
rotate <4,5,6>
scale <7,8,9>
rotate <10,11,12>
// etc
transform spheretransform
#declare spherepos = vtransform(spherepos, spheretransform)
And spherepos will be at the new center of your sphere.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 15 Sep 2004 17:15:38
Message: <4148b0fa$1@news.povray.org>
Though Slime's answer is very thorough, he missed another nice feature...
If you want to rotate a position, simply apply the rotation to a vector
using vrotate, like this:
#declare NewPosition = vrotate(OldPosition,RotationVector);
And voila! The position gets rotated! :-)
Tim
"Tim Nikias v2.0"
Date: 15 Sep 2004 18:30:21
Message: <G7bShDAbHMSBFwNd@econym.demon.co.uk>
>coordinates?
Since it's spherically symmetrical, you can always ask POV where its
centre is.
#declare MySphere =
sphere {0,1
  translate z*10
  rotate SomeVector
#declare Centre = (max_extent(MySphere) + min_extent(MySphere))/2;
Mike Williams
Gentleman of Leisure
Date: 16 Sep 2004 16:15:01
Message: <web.4149f391efcc6b86758848d0@news.povray.org>
Thanks for the pointers on this.  These answers get everything I need to do
and more.
Thanks again - Jeremiah
