POV-Ray : Newsgroups : povray.newusers : Rendering snapshots from Molecular simulations Server Time
17 Jan 2026 16:30:54 EST (-0500)
  Rendering snapshots from Molecular simulations (Message 1 to 5 of 5)
Subject: Rendering snapshots from Molecular simulations
Date: 12 Aug 2004 03:25:01
Message: <web.411b1a56e90e53b3fdeac3b80@news.povray.org>
I would like to start using POV-ray to render images of configurations from
my molecular simulations. I have been using VMD to do this, but I havent
been able to draw my simulation box around my atoms using VMD. Is there an
easy way to do this using POV-ray? I have the configuration in xyz format
Thanks in advance
Pradip
Subject: Re: Rendering snapshots from Molecular simulations
Date: 12 Aug 2004 05:48:06
Message: <411b3cd6$1@news.povray.org>
from
Do you mean draw a box?
Date: 12 Aug 2004 17:00:00
Message: <web.411bd9fb33619d292f7515e00@news.povray.org>
Yes..draw a cube around 256 atoms (sphere). I have never used POV-ray
before..Sorry, if this sounds very trivial.
> from
Date: 13 Aug 2004 04:51:26
Message: <411c810e$1@news.povray.org>
box    {
        <-1,-1,-1>,
        <1,1,1>
    texture { pigment { White } }
... will draw a white coloured box around co-ords -1,-1,-1 and 1,1,1
Change the co-ords to fit the area you want.
use "rgbt <1,1,1,.8>" instead of "White" to make the box partially
transparent
Date: 13 Aug 2004 19:32:58
Message: <411d4faa$1@news.povray.org>
nomail@nomail nous apporta ses lumieres ainsi en ce 12/08/2004 16:58... :
>>from
A start is to put all of those atoms in an union. Then, you can use
min_extent and max_extent to get the corners of the box that is to
contain your atoms.
Something like:
#declare Molecule = union{... put your atoms here ...}
union{
    box{min_extent{Molecule},max_extent{Molecule} pigment{rgbf<1,1,1,0.8>}}
    object{Molecule}//not using pigment here: Assuming that your atoms
are colour coded, blue=nitrogen, red=oxigen, black=carbon, white=hydrogen...
This have the advantage that the box is aotomaticaly sized to your
molecule, and will follow if you change your data.
