POV-Ray : Newsgroups : povray.newusers : Problem with smokegen Server Time
10 Apr 2026 21:44:49 EDT (-0400)
  Problem with smokegen (Message 1 to 3 of 3)
Subject: Problem with smokegen
Date: 24 May 2004 00:45:01
Message: <web.40b17d02b7e8ba459efe766b0@news.povray.org>
I downloaded the smokegen from kieths website and attached the smoke thing
to a cylinder.
i hit raytrace and got this error:
"*SmokeGen is echoing to the message window as Debugging is on (default)*
File: C:Program FilesPOV-RayINCLUDEsmokegen.mry  Line: 289
#read (LmntFile,ecount
,position,size <----ERROR
Parse Error: Expected 'undeclared identifier', size found instead
Returned from renderer with error status"
Couple of important things,i am running moray 3.5 on  windows xp pro.
When i inserted the plugin i attached it to the cylinder. there is a "spline
file?" drop down menu, but when i click it, there is nothing in it. im not
sure if the error is generated be cause i do not have a spline file or not.
Because i have no idea how to create a spline file so if i can get help
with that too that would be great.
i notice the error has something to do with the smokegen.mry file. i
downloaded the plugin from kieths website and have not edited any of the
files in anyway.
Please can anyone reply here or drop me an email. thanks so much.
Subject: Re: Problem with smokegen
Date: 24 May 2004 14:43:53
Message: <cjameshuff-6AF7ED.13442024052004@news.povray.org>
In article <web.40b17d02b7e8ba459efe766b0@news.povray.org>,
Ugh...that's what you get when the author uses lower-case variable names.
The word "size" is now a keyword in the facets pattern, and can't be
used as a variable name. Change all occurrences to "Size", and it'll
work fine...unless there are other conflicts. This is exactly why you
should always put at least one upper-case letter in variable
names...keywords will always be lower-case.
http://tag.povray.org/
Date: 29 May 2004 02:30:00
Message: <web.40b82d8c3a719ce481e1519f0@news.povray.org>
Big thanks mate,
worked like a charm.
for anyone else that has this problem, the above post is the solution!
thanks
