POV-Ray : Newsgroups : povray.newusers : image_map on deformed cylinder Server Time
21 Aug 2025 03:13:35 EDT (-0400)
  image_map on deformed cylinder (Message 1 to 4 of 4)
Subject: image_map on deformed cylinder
Date: 28 Apr 2004 14:15:00
Message: <web.408ff3d3352d67047551a730@news.povray.org>
Hi everyone,
I need to map an image on a deformed cylinder (<0,0,0> , <0,1,0>, 25 scale
<0.5, 1, 1.5> )
When i map an image on it, it's not correct. There are mapping imperfections
on the narrowest edges (on the 2 sides where the radius of curvature is at
its lowest). The part of the image mapped on these sides is more stretched
(horizontally) than the rest. (Actually i map an image that features some
number like 123456790 and the 2 that are on the edges are lot more wider
than the others).
Is there a better way to map an image on a deformed cylinder ?
Here an excerpt of my code :
union {
 cylinder { <0, 0, 0>, <0, 1, 0>, 25
  scale <0.5, 1, 1.5>
   image_map {
    png "C:\Image.388\mapCylinder.png"
    map_type 2
    interpolate 2
    filter all 0.1
  finish { reflection {0.0} ambient 0.0 diffuse 0.3 }
 scale<1,100,1>
Thank you for your help
Dr Doogie
Subject: Re: image_map on deformed cylinder
Date: 28 Apr 2004 18:44:14
Message: <409033be$1@news.povray.org>
Dr. Doogie nous apporta ses lumieres ainsi en ce 2004/04/28 14:11... :
>Hi everyone,
><0.5, 1, 1.5> )
>than the others).
>union {
>  scale <0.5, 1, 1.5>
> texture {
>  pigment {
>   image_map {
>    map_type 2
>    interpolate 2
>    filter all 0.1
> scale<1,100,1>
>Dr Doogie
You use cylindrical maping, so, the image is applied acording to the
*angle* to a solid from whitch the deformed cylinder is carved out. At
the narrow parts, the image get stretched. Thats the why of your problem.
The cure to it:
Solution one: distord your image to compensate. Limits: ONLY works in
that particular case, is you rotate the image around the object, the
distortion will get worst.
Solution two: Use UV-Maping. That way, the image will follow any
deformation you may inflict to your cylinder.
Solution tree: Apply the texture before you scale the cylinder. You may
still see some distortions.
Date: 28 Apr 2004 20:27:46
Message: <cjameshuff-0774D6.20264728042004@news.povray.org>
In article <409033be$1@news.povray.org>, Alain <aze### [at] qwertygov>
These two should give exactly the same results. If the texture is
applied to the cylinder before scaling, it will get scaled along with
the cylinder in exactly the same way. The texture at a point on the
cylinder will match exactly with it's corresponding point on the
deformed cylinder.
http://tag.povray.org/
Date: 29 Apr 2004 01:05:20
Message: <zy4gSAAPPEkAFw+d@econym.demon.co.uk>
Wasn't it Dr. Doogie who wrote:
>Hi everyone,
><0.5, 1, 1.5> )
>than the others).
Try moving the "scale <0.5, 1, 1.5>" out of the cylinder section and
down next to the "scale <1,100,1>" so that it scales the texture as well
as the cylinder.
I imagine that that might push things too far for what you're trying to
achieve, so you'll need to find a happy medium, scaling by something
inside the cylinder section and then by something else after the
texture. Perhaps something like this, adjusting S1 and S2 to taste:
#declare S1=1.1;
#declare S2=2;
  scale <S1, 1, S2>
 scale<0.5/S1,1,1.5/S2>
 scale<1,100,1>
Mike Williams
Gentleman of Leisure
