POV-Ray : Newsgroups : povray.newusers : Flag sample Server Time
11 Apr 2026 00:01:20 EDT (-0400)
  Flag sample (Message 1 to 4 of 4)
Subject: Flag sample
Date: 17 Apr 2004 03:25:01
Message: <web.4080db4980e354073cec3e620@news.povray.org>
I copied the flag sample from the documentation into my own scene.  It works
fine, until I replace the blue texture with an image.  Then the wavy
pattern does not render anymore.  Is it possible to get the wavy pattern
(from varying the surface normal) to work with an image?  How does one need
to modify the code from the documentation?
Thanks,
Eric
Subject: Re: Flag sample
Date: 17 Apr 2004 13:45:33
Message: <40816d3d$1@news.povray.org>
"Eric" <pov### [at] johannsenus> wrote in message
news:web.4080db4980e354073cec3e620@news.povray.org...
works
need
If the example is from section 3.12.3 The Phase Keyword in the Beginning
Tutorial about making animations (only animated flag I could locate) there
shouldn't be any problem replacing Blue with:
image_map { jpeg "yourimage.jpg" }
Using whatever type image you actually have which works with POV, i.e. BMP,
TGA, PNG, etc. Can leave all else the same, although, I'd suggest trying
turbulence 0.5 in the normal to give the waves some distortion.
If you want to go beyond the static object so that it moves too, not just
the normal, then a bicubic_patch is what would work well for that since the
image can be uv_mapped.
Bob H.
http://www.3digitaleyes.com
Date: 18 Apr 2004 15:00:00
Message: <web.4082cf5e37c1021a980530f60@news.povray.org>
I had changed the lighting tags, and that messed up the Phase keyword.
Restoring to the tags from the example made it work.  I guess it's not a
good idea to change two variables at once when learning a new system :-)
Thanks!
Subject: NT: YW! :-)
Date: 19 Apr 2004 02:06:21
Message: <40836c5d$1@news.povray.org>
