POV-Ray : Newsgroups : povray.newusers : Is it possible to have color_map values depend on distance from a point ? Server Time
22 Dec 2025 15:51:23 EST (-0500)
  Is it possible to have color_map values depend on distance from a point ? (Message 1 to 6 of 6)
Subject: Is it possible to have color_map values depend on distance from a point ?
Date: 18 Nov 2003 17:35:01
Message: <web.3fba9d39f0c1c7f425bdb9a40@news.povray.org>
I'm trying to put a coloured bozo 'splodge' on an object, where the
color_map threshold varies from the center to the edge.
At the center of the splodge it should be:
     bozo color_map [0.0 rgbf 1] [0.0 Red ]   ie. all Red
Halfway towards the edge it should be
     bozo color_map [0.5 rgbf 1] [0.5 Red ]   ie. half and half
and at the edge
     bozo color_map [1.0 rgbf 1] [1.0 Red ]   ie. all background
The best approximation I have to this is:
box { <-2,-2,0> <2,2,1 >
    texture { pigment {Green}}
#declare i=0;
#while (i<1.0)
            object {
            sphere { 0 i }
                pigment { rgbf 1 }
                    bozo scale .025
                    color_map {
                        [i rgbf 1]  [i Red]
#declare i=i+0.02;
Which looks OK at at distance, but you can see the bands for the layers
if you are close. Is there a better way to create this effect ?
Thanks,
Bernard
Subject: Re: Is it possible to have color_map values depend on distance from a point ?
Date: 18 Nov 2003 21:47:24
Message: <cjameshuff-C7AE9D.21441218112003@netplex.aussie.org>
In article <web.3fba9d39f0c1c7f425bdb9a40@news.povray.org>,
There are several options. You could create a pigment map with the
spherical pattern...basically what you did with layered textures, but
far more efficient. However, with the example you gave, it would be
simpler to just use a function pattern. Something like this:
            function {
                select(f_noise3d(x/0.025, y/0.025, z/0.025) > f_r(x, y,
z), 1, 0)
            color_map {
                [0.5 color Green]
                [0.5 color Red]
If the noise function (which is just what the bozo pattern is) is less
than the distance, the pattern has a value of 1, otherwise it is 0. You
may also get good results with something like:
function {f_noise3d(x/0.025, y/0.025, z/0.025)*max(0, 1 - f_r(x, y, z))}
This is essentially the same as multiplying bozo and the spherical
pattern. The value of the noise gets scaled down to 0 as the distance
from the origin approaches 1.
http://tag.povray.org/
Subject: Re: Is it possible to have color_map values depend on distance from a point= ?
Date: 19 Nov 2003 12:35:01
Message: <web.3fbba93a2591b98225bdb9a40@news.povray.org>
Christopher James Huff wrote:
>In article <web.3fba9d39f0c1c7f425bdb9a40[at]news.povray.org>,
>    texture {
>        pigment {
>            function {
>z), 1, 0)
>            color_map {
>                [0.5 color Green]
>                [0.5 color Red]
>Christopher James Huff <cja### [at] earthlinknet>
>http://home.earthlink.net/~cjameshuff/
>POV-Ray TAG: chr### [at] tagpovrayorg
Great, I had a feeling there was a simple solution :-)
Your example with the select() seems to need a value that can be +ve or -ve
to work:
eg.
    function {select( f_noise3d(x/0.025, y/0.025, z/0.025) - f_r(x, y,z), 0,
1)}
but the multiplying bozo and the spherical pattern also produced a nice
result:
    function {f_noise3d(x/0.025, y/0.025, z/0.025)*max(0, 1.5 - f_r(x, y,
z))}
Thanks for your help,
Bernard
Date: 19 Nov 2003 22:16:06
Message: <cjameshuff-55CA0B.22111019112003@netplex.aussie.org>
In article <web.3fbba93a2591b98225bdb9a40@news.povray.org>,
> to work:
> eg.
> function {select( f_noise3d(x/0.025, y/0.025, z/0.025) - f_r(x, y,z), 0, 1)}
Er, oops...
> result:
> function {f_noise3d(x/0.025, y/0.025, z/0.025)*max(0, 1.5 - f_r(x, y, z))}
Note that the f_noise3d() function returns a maximum of 1.0, and by
changing the "max(0, 1 - f_r(x, y, z)" to "max(0, 1.5 - f_r(x, y, z))",
you increase the maximum of that factor to 1.5...so the function ranges
from 0 to 1.5, which will be wrapped when used as a pattern. If you want
to change the radius, you should scale the result of the f_r() function
instead:
function {f_noise3d(...)*max(0, 1 - f_r(x, y, z)/1.5)}
You may want to play around with different falloff rates as well...think
about what various n^2 or sqrt(n) do in the range 0..1, or what sin()
does in the ranges 0..pi/2 and -pi/2..pi/2. Or combine several of
these...a cos() function for a ripple effect and a quadratic falloff.
Use atan2() to vary things with angle...
Date: 20 Nov 2003 13:55:00
Message: <web.3fbd0dccbe538fb825bdb9a40@news.povray.org>
>instead:
I see what you mean, I had just been trying to increase the 'density'
of the pattern in the middle.
If only I could remember all the maths that I learnt years ago :-) , I
did manage to play around and produce a spirally thing:
function{f_noise3d(x/0.025,y/0.025,z/0.025)
    *(1+cos(7*atan2(x,y)+15*f_r(x,y,0)/2))
    *max(0, 1.0 - f_r(x, y, z)/2.0)}
Thanks,
Bernard
Date: 21 Nov 2003 15:15:06
Message: <cjameshuff-D3E750.15094821112003@netplex.aussie.org>
In article <web.3fbd0dccbe538fb825bdb9a40@news.povray.org>,
Hmm...a better way of doing that would be to just adjust the minimum of
the range of the noise function until its minimum and maximum are 1.
Um...
f_noise3d(...)*min(1, f_r(...)) + 1 - min(1, f_r(...))
At r = 0, noise will be multiplied by 0 and the function result will be
1. At r >= 1, the function will be pure noise. Or flip it around, making
a porous hole in an otherwise solid function:
f_noise3d(...)*max(0, 1 - f_r(...)) + min(1, f_r(...))
Or simpler, use the adj_range() function in math.inc:
adj_range(f_noise3d(...), min(1, f_r(...)), 1)
This might actually be faster, because of one less evaluation of
f_r()...it depends on how much overhead the function call takes.
Here's an interesting version I came up with:
function {adj_range(f_crackle(x*5, y*5, z*5), cos(pi*max(0, 1 - f_r(x/5,
y/5, z/5)))/2 + 0.5, 1)}
Well, I find the most important thing is to just remember what the
various functions look like when graphed, and figure out what they "look
like" when combined.
