POV-Ray : Newsgroups : povray.newusers : Normal bumpiness Server Time
10 Apr 2026 01:42:40 EDT (-0400)
  Normal bumpiness (Message 1 to 6 of 6)
Subject: Normal bumpiness
Date: 18 Nov 2003 11:20:01
Message: <web.3fba4674abf4a7bc6b7c745d0@news.povray.org>
Hi all
Yet another question..
I'm creating several spheres in a scene, and I added bumpiness with the
"normal" keyword.
I just discovered that each time I render the scene, the bumpiness stay the
same. Isn't a random function?
I thought it would change from one render to another.. but.. since I wanted
the bumpiness to stay the same, it's perfectly fine for me.. I also wanted
to make sure it will always behave like that.
Thanks!
O.
Subject: Re: Normal bumpiness
Date: 18 Nov 2003 11:46:10
Message: <3fba4cd2$1@news.povray.org>
the
Povray makes use of pseudo-random streams, but for normals, it uses the
inbuilt patterns, and they're not random at all. And even if you use the
rand()-stream to actually randomize the "location" of the pattern, then it
will stay the same as long as the seed isn't changed. I'm not too sure about
different platforms though, some Guru needs to answer that.
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Date: 18 Nov 2003 12:50:01
Message: <web.3fba5b524daf0e006b7c745d0@news.povray.org>
Ok, as long as I have the assurance that the bump pattern won't change if I
don't move the sphere, it's fine.
Thanks!
O.
Date: 18 Nov 2003 14:16:05
Message: <cjameshuff-9FEC18.14125118112003@netplex.aussie.org>
In article <3fba4cd2$1@news.povray.org>,
> the
Pseudo-random, and reproduceable.
The noise patterns will be identical on any platform. The only things
that vary from render to render are jitter and crand, which is one
reason they are discouraged in animations.
http://tag.povray.org/
Date: 18 Nov 2003 14:43:16
Message: <SwanzDAtTnu$EwlP@econym.demon.co.uk>
You just have to be careful about how you move the object. In this first
example the two spheres have exactly the same bumps:
sphere {0,1 pigment {rgb 1}
 normal {bumps scale 0.1}
 translate <2,0,0>
But in this second example the patterns of the bumps are different.
 translate <2,0,0>
What happens is that POV has a sort of random bump field that pervades
the whole of 3d space, and which becomes visible only when you put a
surface in that space. In the first example, the two spheres pick up
their bumps from the same place in the 3d bump field, and then one of
them moves sideways taking those bumps with it.
In the second example the sphere moves sideways first, and then has
different bumps from the new location applied to it.
Syntax like the following is used in animations where you want the
object to keep the same pattern as it moves through space, like real
solid objects do. You can be assured that this will always keep the same
pattern - if it didn't it wouldn't be possible to represent a realistic
textured object in a POV animation.
 pigment {bozo scale 0.1}
 translate <2*clock,0,0>
Mike Williams
Gentleman of Leisure
Date: 18 Nov 2003 15:15:01
Message: <web.3fba7cf54daf0e006b7c745d0@news.povray.org>
It's exactly what I observed. I had 25 spheres with the same pattern..
because I created all of them at 0,0,0. I just figured out what you
explained here and created the spheres at different places.. et voila!
Thanks for the help!
O.
