POV-Ray : Newsgroups : povray.newusers : Cutaway of helix isosurface leaving unwanted artifacts Server Time
30 Sep 2024 22:13:28 EDT (-0400)
  Cutaway of helix isosurface leaving unwanted artifacts (Message 1 to 3 of 3)
Subject: Cutaway of helix isosurface leaving unwanted artifacts
Date: 13 Nov 2003 13:15:01
Message: <web.3fb3c9faf4909c64a09175c60@news.povray.org>
Hello all.  This is my first post.  Hope I'm following protocol.
Below is code I wrote for the difference between a helix isosurface and a
box.  As you can see the box is removing the section of helix but leaving
an artifact.  Can anyone explain how to fix this?  Thanks in advance.
#include "functions.inc"
global_settings {
        assumed_gamma 1.3
        max_trace_level 5}
camera { location <3,3,-4>
         look_at <1,0,0>}
light_source {<10, 20, -30> color Gray25}
sky_sphere {pigment {gradient y color_map {[0, 1  color Gray50 color
Gray80]}}}
plane { y, -1.25 pigment {checker color Gray40 color Gray80 scale <1, 1,
10000> rotate y*45} finish { ambient 0.45 }}
#declare IsoTexture = texture { pigment { rgb <1.0, 0.8, 0.5> } finish {
phong 0.6 phong_size 250 } }
#declare spring =
         isosurface {
                        function { f_helix1(x,y,z, 1, 20, 0.0875, 0.75, 1,
1, 0) }
                  contained_by { box { <-1, -2.2, -1>, <2, 2, 2> } }
                  max_gradient 5
                  texture { IsoTexture }
                  no_shadow
                  scale <1,1,-1>
                  rotate <0,0,90>
#declare cutaway =
        box { <-10,0,0> <20,100,-100> pigment {White}
difference{
        object{spring}
        object{cutaway}
Subject: Re: Cutaway of helix isosurface leaving unwanted artifacts
Date: 13 Nov 2003 14:05:02
Message: <web.3fb3d5cdec150afcd6c93cf30@news.povray.org>
In the documentation on Isosurface objects, it specifically mentions your
problem.  It is related to performing CSG operations on isosurfaces.  Check
out the following link and look for max_trace and all_intersections.
http://www.povray.org/documentation/view/169/
Bill
Date: 13 Nov 2003 14:40:00
Message: <web.3fb3dd37ec150afca09175c60@news.povray.org>
>Bill
Wow!  Thanks so much for the help; that fixed it nicely.  When all else
fails, read the directions AGAIN!
