POV-Ray : Newsgroups : povray.newusers : read df3 in a loop Server Time
18 Jan 2026 03:27:57 EST (-0500)
  read df3 in a loop (Message 1 to 2 of 2)
Subject: read df3 in a loop
Date: 29 Sep 2003 11:40:01
Message: <web.3f7851f2317d154499cf94980@news.povray.org>
Hello
I have a Problem reading some density files in a while loop.
The povray script should do following:
1. read a density file (e.g. tempn1.df3) and render a pictures, which is
stored as a tga or so.
2. read the next density file (e.g. tempn2.df3) adn do the same as before
3. loop it
I don't know how you can give a loopvariable in while for a filename.
density {
         density_file df3 "test1.df3"
   interpolate 1
   color_map {
      [0.00 rgb <0,0,0>]
   [0.40 rgb <0 0 1>]
      [0.50 rgb <0,1,0>]
   [0.60 rgb <1,0,0>]
      [1.00 rgb <1,0,0>]
How can I make test1.df3 to testx.df3, whereas x means x=1...n
Thank you very much for Your apprecaited help.
Wolfgang
Subject: Re: read df3 in a loop
Date: 29 Sep 2003 14:33:07
Message: <3f787ae3@news.povray.org>
  You can't render pictures in a while-loop. You use POV-Ray's animation
rendering options and use the 'clock' or 'frame_number' variables (in your
case the latter is probably easier) to do the job.
density {
         density_file df3 concat("test", std(frame_number, 0, 0), ".df3")
