POV-Ray : Newsgroups : povray.newusers : Installing on RH Linux 9 Server Time
1 Oct 2024 05:21:38 EDT (-0400)
  Installing on RH Linux 9 (Message 1 to 2 of 2)
Subject: Installing on RH Linux 9
Date: 20 Jul 2003 03:50:01
Message: <web.3f1a48eef8ade8ceade7500c0@news.povray.org>
I am trying to install POV Ray on my linux system.  If I try to install it
through  an RPM, then I receive an error that says "Package not found
libpng.so.0".  I also tried to install using the source files but after I
ran ./install and navigated to the newly copied folder in
/usr/local/share/povray-3.5 I can't run ./configure in the folder as the
instructions said.  What am I missing?  If this is a RTFM moment then tell
me where in the manual I need to go and I'll do it.
Subject: Re: Installing on RH Linux 9
Date: 21 Jul 2003 04:52:45
Message: <3f1ba9dd$1@news.povray.org>
> libpng.so.0".
Maybe you don't have PNG-Support installed. Search for a RPM called
libpng*.rpm on the RedHat CDs. Install it an try again to install
POV-Ray. Or maybe libpng is not called "libpng.so.0". Then a symbolic
link (ln -s) could help you.
This is what I would try,
Bonsai
    ___ __ __  _ ___ ___  _
   | _ )  \  \( )  _) _ )( )
   | _ \() |\ \ |\ \/ _ \| |
   |___/__/_)\__)___)/ \_)_)
        www.b0n541.net
