![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I have just come back to povray after about 7 years and it just seems to get
better and better!
Anyway, my problem is this.
I wish to apply a texture and put a gif on top with some transparent
(filtered) colours. However, this does not seem to work - please help.
Ths colour (#140) is transparent if I comment out the first texture but
shows up in the second.
My code -
granite
colour_map {
[0.0 colour rgb <0.95,0.98,1>]
[0.2 colour rgb <0.95,0.98,1>]
[0.4 colour rgb <0.92,0.93,0.97>]
[0.8 colour rgb <0.89,0.92,0.95>]
[1.0 colour rgb <0.95,0.98,1>]
image_map {
gif "logo3.gif" once
filter 140, 1.0
rotate <0,-90,0>
scale 1
translate <0,4.2,0.35>
I am using version 3.5 Unix (.Linux.gcc)
Thanks in advance.
David
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"David" <dh2### [at] iucr org> wrote in message
news:web.3f0e7f374965b1c45c8e72650@news.povray.org...
get
> better and better!
Welcome back. Quite a hiatus from POV-Ray, glad you found your way to here.
It could be that index 140 isn't pure white (in POV terms being:
<255,255,255>/255) and so not doing as you might be expecting. The keyword
'transmit' might be needed, instead of 'filter'.
> texture {
> pigment {
> granite
> colour_map {
> texture {
> pigment {
> image_map {
> filter 140, 1.0
> rotate <0,-90,0>
> scale 1
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>news:web.3f0e7f374965b1c45c8e72650[at]news.povray.org...
>> better and better!
Thank you I am very please to be here again.
Thanks! Using transmit worked! As an aside - It seems the color doesn't have
to be white - the colour I made transparent was pure red.
Thanks again!
Best wishes,
David
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
