POV-Ray : Newsgroups : povray.newusers : iso_csg.inc question Server Time
18 Sep 2025 18:33:55 EDT (-0400)
  iso_csg.inc question (Message 1 to 7 of 7)
Subject: iso_csg.inc question
Date: 24 Jun 2003 23:30:01
Message: <web.3ef9165ee559a9c37196f5900@news.povray.org>
OK, what really dumb mistakes am I making?
#declare this_function =IC_Sphere(<0,0,0>, 1);
isosurface { function { this_function }
      contained_by { box { -2, 2} }
                        texture { pigment { color rgb <0.5, 0.5, 0> } }}
returns:
While
#declare this_function = IC_Sphere(<0,0,0>, 1);
isosurface { function { this_function(<0,0,0>,1) }
returns:
So, leaving out the #declare statement entirely, and going it directly:
isosurface { function { IC_Sphere(<0,0,0>, 1)}
highlighting the first line of below:
function {
    f_sphere(x-Cx, y-Cy, z-Cz, _ICSG_Radius)
and returning the error message:
(I started with the IC_HF_Sphere function, but to make sure my problem
wasn't somehow with my image map, I simplified to the above, with the same
results.)
Normally, after several hours, I can fight my way through my obtuseness, but
not this time.
Please help.
Subject: Re: iso_csg.inc question
Date: 25 Jun 2003 02:54:13
Message: <3ef94715$1@news.povray.org>
In article <web.3ef9165ee559a9c37196f5900@news.povray.org> , "Dave Matthews"
Maybe you should read the POV-Ray 3.5 manual how to use functions first?
This is no valid syntax at all!
    Thorsten
Date: 25 Jun 2003 03:18:46
Message: <3EF94CD5.C5D5505F@gmx.de>
Like Thorsten said your syntax is simply not valid - none of the methods
you tried could be found anywhere in the docs or sample scenes of IsoCSG
or POV-Ray.
The correct syntax can be found in any of the sample scenes coming with
the library.  It would be strongly advisable to also read the relevant
chapters of the POV-Ray docs.
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
Date: 25 Jun 2003 10:30:01
Message: <web.3ef9b16c7472fddc7196f5900@news.povray.org>
Thorsten Froehlich wrote:
>In article <web.3ef9165ee559a9c37196f5900[at]news.povray.org> , "Dave Matthews"
Believe me, I did, but I missed the only example that showed how to use a
#declare with a function, i.e.
"3.6.3.5 Combining isosurface functions"
Obviously, else it would have worked, wouldn't it.
>    Thorsten
Anyway, after re-looking through the manual, yes, I realized that I needed
to use:
function { this_function(x,y,z) } and now it works.
Sorry for wasting your time.
Date: 25 Jun 2003 10:35:01
Message: <web.3ef9b1fd7472fddc7196f5900@news.povray.org>
>the library.
You're right.  I don't know why I didn't look at the sample scenes.  Sorry.
Dave
Date: 25 Jun 2003 16:01:27
Message: <3ef9ff97$1@news.povray.org>
Dave Matthews <mat### [at] dinecollegeedu> wrote in message
news:web.3ef9b1fd7472fddc7196f5900@news.povray.org...
> >the library.
Sorry.
> Dave
bleh! sometimes you just need to post here to get a fresh perspective on
mess-ups and clear your head.
Date: 30 Jun 2003 16:44:08
Message: <3F00A11E.7090101@dinecollege.edu>
In which case, it definitely worked (but I'll try to avoid this method
in the future.)
After getting the rather-more-politely-worded advice to RTFM, which also
means
re-RTFM, I did re-RTFM, and found:
(In section 6.5.4.2 Functions in Isosurface)
"By default a function takes three parameters (x,y,z) and you do not
have to explicitly specify the
parameter names when declaring it.  When using the identifier, the
parameters must be specified."
which exactly answered my question, and I could swear was not there the
first 50 or so times
I read the manual.
Someplace I learned the advice, which I must remember to follow:
(and I'm probably messing up the syntax and/or the logic, but I'm not
going to ask about it!)
#while ((hell_frozen_over = 0) & (understanding < 1) )
read(manual)
evaluate(understanding)
evaluate(hell_frozen_over)
which, I know, might include an extra evaluation of the status of hell,
but that's usually something
good to know for other purposes, anyway.
Dave
