POV-Ray : Newsgroups : povray.newusers : Wire aspect Server Time
22 Dec 2025 21:17:46 EST (-0500)
  Wire aspect (Message 1 to 4 of 4)
Subject: Wire aspect
Date: 16 Jun 2003 06:35:01
Message: <web.3eed9c29df524817cd0ca0@news.povray.org>
Hello
I've got a mesh object and i'd like it to appear only as wireframe, how
could I do this ?
Thanks in advance,
O.Leonard
Subject: Re: Wire aspect
Date: 16 Jun 2003 06:38:51
Message: <3eed9e3b$1@news.povray.org>
You cant. Unless you have access to the triangle-corners
themselves and thus are able to build your own wireframe-
view using cylinders+spheres, POV-Ray doesn't support
wireframe viewing, as it is a raytracer. Ergo it shoots rays
into the scenery and displays what it hits. Wireframe normally
is projecting the edges as lines onto the screen, and this isn't
done in POV-Ray.
Tim
Tim Nikias v2.0
Email: Tim### [at] gmxde
> Hello
> could I do this ?
> Thanks in advance,
> O.Leonard
Date: 16 Jun 2003 07:42:42
Message: <3eedad31@news.povray.org>
Olivier Leonard wrote:
> Hello
> could I do this ?
> Thanks in advance,
> O.Leonard
If you can import your mesh into Blender, you can use the Povanim script to
export it to Pov. If you select Wire in Blenders material window, it will
export the Mesh as a wireframe made out of cylinders.
Daniel
Date: 16 Jun 2003 08:00:02
Message: <web.3eedb09868701e0a736664ab0@news.povray.org>
>Hello
>could I do this ?
>Thanks in advance,
>O.Leonard
If you have a mesh 1 object, you can use the mesh includes of Chris Colefax.
See
http://www.geocities.com/SiliconValley/Lakes/1434/tutorials/pcm/index.html.
The wire_mesh macro and the cylinder_mesh macro show wireframes.
Norbert
