![](/i/fill.gif) |
for as far as i know your methode of creating a tube is the only (usefull)
one. You could even make a macro for it :-).
//start of macro
#macro Tube (Lenght, Inner_Diam, Outer_Diam)
difference{
cylinder{<0,0,0>, <Lenght, 0,0>, Outer_Diam}
cylinder{<-1,0,0>, <Lenght+1, 0,0>, Inner_Diam}
//end of macro
object{Tube(1, 2, 3) pigment {Red}} //shows a tube with lenght 1,
Inner_Diam 2, Outer_Diam 3 (and a red color)
"Tabea" <hio### [at] web de> wrote in message
news:web.3ea6463e139c24052b26ab750@news.povray.org...
> Hi,
> except of a difference between two cylinders?
> things that are allready exist.
> Tabea
> P.S. I love povray its hard to learn yes but why should i buy a prog for
> 2000? or more? Hope sometimes i make some nice pics.
![](/i/fill.gif) |
![](/i/fill.gif) |
In article <web.3ea6463e139c24052b26ab750@news.povray.org>,
I'm not sure what you expect to be better. It is the most common way of
doing it. You could generate a mesh or use a lathe, but why?
Well, they are well documented. Here's an example that does what you
asked about:
#macro Tube(Start, End, IRad, ORad)
#local Axis = vnormalize(End - Start);
difference {
cylinder {Start, End, ORad}
cylinder {Start - Axis*0.001, End + Axis*0.001, IRad}
If you still have problems, you are going to need to be more specific.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
![](/i/fill.gif) |
