POV-Ray : Newsgroups : povray.newusers : Polarization? Server Time
1 Oct 2024 07:22:18 EDT (-0400)
  Polarization? (Message 1 to 2 of 2)
Subject: Polarization?
Date: 26 Mar 2003 21:20:06
Message: <web.3e825f0be67df3ed21c223460@news.povray.org>
Is there any way to model a polarizing filter in POVray?  Not the actual
polarization of light, but deviations in ray path due to the 57 degree
angle of the glass fibers?
Any ideas? or am I totally off base (ie. just treat it as a sheet of glass
with an angle of refraction) -- I'm trying to model light passing through
an lcd on a larger scale, so I believe I should try and approximate the
photorefractive effects of the polarizing layers..
Thanks,
Matty U!
Subject: Re: Polarization?
Date: 31 Mar 2003 22:29:19
Message: <cjameshuff-3FC190.22294731032003@netplex.aussie.org>
In article <web.3e825f0be67df3ed21c223460@news.povray.org>,
Deviations in ray path? Angle of glass fibers? What fibers?
You mean index of refraction? POV can model refraction, it can not model
polarization. This doesn't mean you can't make an illustration of an
effect with POV, you just can't do the simulation directly. For more
specific advice, you are going to have to give more information.
Simulating an LCD would require some pretty special-purpose coding, POV
is not capable of it.
http://tag.povray.org/
