POV-Ray : Newsgroups : povray.newusers : RGB XYZ Server Time
21 Mar 2026 18:19:54 EDT (-0400)
  RGB XYZ (Message 1 to 4 of 4)
Subject: RGB XYZ
Date: 27 Jan 2003 00:35:03
Message: <web.3e34c4ce3b1298dc7b3d0bb20@news.povray.org>
This was a little script I threw together when I had trouble with the
coordinate system.  It helped me figure out how things would move and/or
rotate.  I'm posting it here so, perhaps, it can help others.
#declare marker =
  union {
    cylinder { <0,0,0>,<1,0,0>,.1 pigment { rgb <1,0,0> } }
    cone { <1.3,0,0>,0,<1,0,0>,.2 pigment { rgb <1,0,0> } }
    cylinder { <0,0,0>,<0,1,0>,.1 pigment { rgb <0,1,0> } }
    cone { <0,1.3,0>,0,<0,1,0>,.2 pigment { rgb <0,1,0> } }
    cylinder { <0,0,0>,<0,0,1>,.1 pigment { rgb <0,0,1> } }
    cone { <0,0,1.3>,0,<0,0,1>,.2 pigment { rgb <0,0,1> } }
Subject: Re: RGB XYZ
Date: 27 Jan 2003 00:58:03
Message: <3e34ca6b@news.povray.org>
That's pretty nifty!
If only I could remember which way to rotate...
Date: 27 Jan 2003 07:52:16
Message: <3e352b7f@news.povray.org>
  It's simple. There's a good way described in the documentation.
Using your left hand, point your thumb towards the positive axis around
which you want to rotate; your other fingers will tell you the direction
of the rotation (when rotating by a positive angle).
Date: 27 Jan 2003 08:33:57
Message: <3e353545$1@news.povray.org>
Yeah, I remember reading that, but then I couldn't remember, "How was it
that I was supposed to hold my thumb?"  ;-)  I generally just think, "Oops!
The other direction."  Although it does make things more difficult when
rotating around more than one axis at a time...
