POV-Ray : Newsgroups : povray.newusers : problems using clipped_by Server Time
23 Dec 2025 01:03:52 EST (-0500)
  problems using clipped_by (Message 1 to 3 of 3)
Subject: problems using clipped_by
Date: 2 Jan 2003 14:15:04
Message: <web.3e148eba32b2214528b61af20@news.povray.org>
I'm getting some unexpected (at least by me) results using the "clipped_by"
operator in POVray.
Specifically, when I clip triangle mesh objects, I get empty spaces where
I believe I should be getting objects.  It is as if the ray is terminated
by the clipped off part of the object and background color is rendered.
For instance, I rendered a simple open-ended cylinder using an OpenGL-based
application (screen grab at
ftp://ncmir.ucsd.edu/outgoing/spl/sv_cylinder.gif)
and with POVray (ftp://ncmir.ucsd.edu/outgoing/spl/pov_cylinder.gif).
Then I moved in the front clipping plane and rendered again,
 ftp://ncmir.ucsd.edu/outgoing/spl/sv_clipped_cylinder.gif
and
 ftp://ncmir.ucsd.edu/outgoing/spl/pov_clipped_cylinder.gif
show the OpenGL and POVray results, respectively.
The POVray scripts and the mesh file may be found at
and
 ftp://ncmir.ucsd.edu/outgoing/spl/cyl_synu.pov
The files are a bit ugly since they're machine generated but should be
fairly self explanatory.  The "clipped_by" operators are invoked at about
line 536 in both files.  The __far_clip is outside the bounding box of the
object.
Does "clipped_by" only work with non-mesh type objects?
Any clues or RTFMs welcome.
       spl
Subject: Re: problems using clipped_by
Date: 2 Jan 2003 20:52:26
Message: <3E14EC79.55865C2D@pacbell.net>
> operator in POVray.
snip
Look for section 6.5.2.3.1  Solid Mesh and inside_vector in the docs :)
Ken Tyler
Date: 4 Jan 2003 11:15:04
Message: <web.3e1707bcc82fabb989b1b69d0@news.povray.org>
Exactly the RTFM I was looking for!
I can hardly wait till the PDF version of the manual comes out and I
can print it for desk reference.
Thanx!
       spl
