POV-Ray : Newsgroups : povray.newusers : This may not be a newbie question, just a syntax question. Server Time
23 Dec 2025 02:55:22 EST (-0500)
  This may not be a newbie question, just a syntax question. (Message 1 to 3 of 3)
Subject: This may not be a newbie question, just a syntax question.
Date: 8 Nov 2002 02:20:03
Message: <web.3dcb64d81d8cd29dfeecdaa90@news.povray.org>
I'm trying to use the HF_ functions in shapes.inc to generate a mesh from a
small .png file.
I simply added a new funtion to the example file given in the include files
demo. When I did, I got an error.
#declare MyFunction = function{pattern {bumps scale 0.2}}
 // MyFunction above works...
#declare MyTest = function
 { pigment
   { image_map
     {png "testHF.png"
      map_type 0 interpolate 2
  } // <- this replacement produces an error.
    // shapes.inc pops up and marks the bit of code named above
object {
   HF_Square
    ( MyTest, // MyFunction was here, but I replaced it.
      off,
      off,
      <60,60>,
      on,
      <0.0, 0.1, 0.0>,
      <1.5, 0.5, 1.5>
      pigment {color rgb 1}
      finish {ShinyFinish}
   translate <-3.0, 0.0,-3.2>
// The error that happens pops up shapes.inc and a line in the
// HFCreate_() macro gets marked. See note below.
  #local J = 1;
   #while (J<=xRes)
      #local K = 1;
      #while (K<=zRes)
         PArr[J][K],   // <-- this code gets highlited in yellow
         #declare K = K+1;
      #declare J = J+1;
What do I do to get an image file used as a function?
normdoering
Subject: Re: This may not be a newbie question, just a syntax question.
Date: 8 Nov 2002 06:02:09
Message: <r66nsuctqaldv3n95jjai52h1j7h6s6amt@4ax.com>
On Fri,  8 Nov 2002 02:16:40 EST, "normdoering" <nor### [at] yahoocom> wrote:
You are trying to put color as float, try pattern as pigment in your function
definition.
Moreover read rules about crossposting posted in faq droup.
ABX
Date: 8 Nov 2002 23:07:49
Message: <pan.2002.11.09.04.06.46.423259.221@gte.net>
On Fri, 08 Nov 2002 05:59:38 -0500, ABX quoth:
You need to work on your spelling.  Everyone *knows* it's "froup", not
"droup". :-)
Mark
