![](/i/fill.gif) |
I'm trying to use the HF_ functions in shapes.inc to generate a mesh from a
small .png file.
I simply added a new funtion to the example file given in the include files
demo. When I did, I got an error.
#declare MyFunction = function{pattern {bumps scale 0.2}}
// MyFunction above works...
#declare MyTest = function
{ pigment
{ image_map
{png "testHF.png"
map_type 0 interpolate 2
} // <- this replacement produces an error.
// shapes.inc pops up and marks the bit of code named above
object {
HF_Square
( MyTest, // MyFunction was here, but I replaced it.
off,
off,
<60,60>,
on,
<0.0, 0.1, 0.0>,
<1.5, 0.5, 1.5>
pigment {color rgb 1}
finish {ShinyFinish}
translate <-3.0, 0.0,-3.2>
// The error that happens pops up shapes.inc and a line in the
// HFCreate_() macro gets marked. See note below.
#local J = 1;
#while (J<=xRes)
#local K = 1;
#while (K<=zRes)
PArr[J][K], // <-- this code gets highlited in yellow
#declare K = K+1;
#declare J = J+1;
What do I do to get an image file used as a function?
normdoering
![](/i/fill.gif) |
![](/i/fill.gif) |
On Fri, 8 Nov 2002 02:16:40 EST, "normdoering" <nor### [at] yahoo com> wrote:
You are trying to put color as float, try pattern as pigment in your function
definition.
Moreover read rules about crossposting posted in faq droup.
ABX
![](/i/fill.gif) |
![](/i/fill.gif) |
On Fri, 08 Nov 2002 05:59:38 -0500, ABX quoth:
You need to work on your spelling. Everyone *knows* it's "froup", not
"droup". :-)
Mark
![](/i/fill.gif) |
