POV-Ray : Newsgroups : povray.newusers : Isosurface troubles Server Time
21 Nov 2025 14:48:42 EST (-0500)
  Isosurface troubles (Message 1 to 3 of 3)
Subject: Isosurface troubles
Date: 22 Oct 2002 13:15:17
Message: <web.3db5874eec4f27f545704aba0@news.povray.org>
The following is a scene of a narrow canyon. How do I get the groove do bend
left or right, so I can see the canyon curve to the left and right(and set
the bounding box smaller) ?
// The_Gash.pov
#include "functions.inc"
#include "math.inc"
#include "transforms.inc"
global_settings {
  assumed_gamma 1.0
  location  <0.0, 7.0, 40.0>
  direction 1.5*z
  look_at   <0.0, 5.0,  0.0>
sky_sphere {
  pigment { rgb <0.6,0.7,1.0>
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-10, 40, -30>
light_source {
  translate <40, 10, 30>
// create a isosurface object - the equipotential surface
// of a 3D math function f(x, y, z)
//#declare fn_X = function(x,y,z) {  x*x + y*y - 1 + pow(2,abs(x)) }  //
cylinder function
isosurface {
  function {-pow(2,abs(x))+y-f_noise3d(x*5, y*5, z*5)*2+2-f_noise_generator
(x,y,z, 1)*2 } //open
  contained_by { box { <-40,-8,-80>, <40,16,80> } }
  accuracy 0.01
  max_gradient 4
  pigment {Brown}
 Shear_Trans(x, y, cos(z))}
plane{
 y,3  pigment { rgbf <0,0,1,.1> }
        normal{ dents turbulence <5.0, 0.6, 0.1> } interior { ior 1.33 }
finish{ ambient .1 diffuse .9 reflection 0.3 }}
Subject: Re: Isosurface troubles
Date: 22 Oct 2002 17:39:26
Message: <auRtmJA2Uct9EwlZ@econym.demon.co.uk>
Do you mean something like
function {-pow(2,abs(x-(z*z/800)))+y-f_noise3d(x*5, y*5, z*5)*2
+2-f_noise_generator(x,y,z, 1)*2 } //open
The smaller the value (800 in the above) the tighter the curve, but if
you set it much smaller you have to move the camera so that it stays
outside the object.
Mike Williams
Gentleman of Leisure
Date: 25 Oct 2002 20:20:07
Message: <web.3db9dedda377afbbe86ba830@news.povray.org>
It set me in the right direction...
function {-pow(2,abs(x-(.5*z*cos(z/180))))+y-f_noise3d(x*5, y*5, z*5)*2
is closer to what I had in mind. Thanks.
