![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I have this object that uses a whole bunch of random values, but it seems
that every time I run the scene, it looks exactly the same. Here's the
relevent code (since regular inequality signs won't work in web view here, I
am replacing them in this message with [ and ]):
#declare Conifer_Cluster =
union
#declare numNeedles = 5 + rand(seed(12))*5;
#declare iter = 0;
#while(iter [ numNeedles)
object { Conifer_Needle rotate
[rand(seed(iter))*80,0,rand(seed(iter))*80] }
#declare iter = iter+1;
rotate [-40,0,-40]
rotate [90,0,0]
This is to generate a cluster of pine needles. The object referred to in the
code called "Conifer_Needle" is just a simple slender cylinder. Every time
I run this, there are exactly 5 needles created and they are always in the
same position. So I'm not getting some aspect of the random number
generation in POV-Ray... What do I need to do to get different results each
time? The reason it needs to be different is that later on I am going to
have another object that will refer to this object within a #while loop.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The random-number generator of POV-Ray will always
yield the same row of numbers, no matter which
frame of animation your in. Just imagine you'd randomly
placed an object in a box, it would be jumping all
over the box for each new frame, something not very
desirable.
Also, what you're doing, is initializing the seed again
every time you require a new random number, and thus
get the first random number from those series.
You should rather use:
#declare Seed=seed(1);
and then "rand(Seed)" everywhere where you require a
random number.
In your case:
union
#declare iter = 0;
#declare IterSeed=seed(iter);
[rand(IterSeed)*80,0,rand(IterSeed)*80] }
rotate [-40,0,-40]
rotate [90,0,0]
Still, every new frame of an animation will use the
same random-numbers, you could only go about this
like this:
#declare IterSeed=seed(iter+clock*1000);
Look at the docs about rand / seed to find out more
about the pseudo-random-stream this function returns.
Regards, Tim
Tim Nikias
Email: Tim### [at] gmx de
I
> union
> #declare iter = 0;
> #end
> rotate [-40,0,-40]
> rotate [90,0,0]
the
each
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Besides the fact that rand() always returns the same number sequence for
a given seed, you are using rand() in the wrong way.
This is how rand() should be used:
union
#declare Conifer_Seed = seed(0); // or whatever number you like
#declare numNeedles = 5 + rand(Conifer_Seed)*5;
#declare iter = 0;
#while(iter < numNeedles)
object
{ Conifer_Needle rotate<rand(Conifer_Seed)*80,0,rand(Conifer_Seed)*80> }
rotate <-40,0,-40>
rotate <90,0,0>
Since there's no variable in POV-Ray which changes from render to render,
there's no way of getting a different seed from render to render.
However, in an animation it's possible, as there are variables which
change. The most useful is 'frame_number'.
Thus, in an animation you could change the Conifer_Seed declaration above
to look like this:
#declare Conifer_Seed = seed(frame_number);
This way you get a different distribution for each frame of the animation.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ah, I think I understand a little better now. Thanks. It is strange, though,
that there isn't a way to seed using the internal clock of the computer, as
most programming languages I've used are able to do.
Thanks for the help.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That's one of the MegaPOV features that didn't make it into POV 3.5.
MegaPOV has a variable called "tick_count" which returns the current
value of the CPU clock, so you could say "seed(tick_count)".
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <web.3d9e6370c254ce755de492f30@news.povray.org> , "Justin Smith"
It would be of no help to you if objects would be constantly moving every
time you render the scene.
Thorsten
e-mail: tho### [at] trf de
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thorsten Froehlich wrote:
>In article <web.3d9e6370c254ce755de492f30[at]news.povray.org> , "Justin Smith"
Well, it would if they were minor background objects and I was trying to
generate random terrain each time, or something like that. If I wanted to
generate a random tree, and then generate another random tree in a
different scene, I wouldn't want them too look the same, and I'd rather not
have remember all the past seeds I've used on past trees. Well, its a minor
point, anyways.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
