![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm using a 500x500 pixel .png to make a heightfield as a basis for a
landscape I'm creating. The trouble is, the coloration is all patchy in
places. This is not the regular problem of the normal flipping that can be
solved by double-illuminate, and it has nothing to do with my texture map,
since all I'm using is a green pigment (for right now, anyway). I've
searched these newsgroups, and the responses I've seen all mention using
smaller heightmaps. So I cut it down to 4 maps of half size, 250x250. But
the scene still looks exactly the same, except now I have ugly seams where
the heightfields join up.
Could I be using double-illuminate wrongly? Any other ideas?
//the scene file:
camera{
location <450,120,-450>
look_at <0,-50,0>
camera{
location <40,1300,-45>
look_at <0,75,0>
light_source{
<2000,2000,-2000> color White
sky_sphere {
gradient y
color_map{
[ 0.0 rgb <0.180392, 0.4, 0.913725> ]
[ 1.0 rgb <0.541176, 0.74902, 1.0> ]
scale .4
translate .7
fog {
distance 1000
color rgbt<0.541176, 0.74902, 1.0,.35>
#declare Terrain=
union{
height_field{
png "HMap.png" //this is the main heightfield
double_illuminate // I've stuck this in elsewhere, but with no luck.
smooth on
water_level 0
pigment{color rgb<0,.7,0> }
finish{ambient .3}
height_field{
png "HMap2.png" //this is just background
// smooth on
water_level 0
pigment{color rgb<0,.7,0>}
finish{ambient .3}
translate<-1,0,0>
height_field{ //this is just background
png "HMap3.png"
// smooth on
water_level 0
finish{ambient .3}
translate<0,0,1>
png "HMap4.png"
// smooth on
water_level 0
finish{ambient .3}
translate<-1,0,1>
object{
Terrain
scale <1000,100,1000>//scale <1000,150,1000>
translate <-500,0,-500>
rotate<0,0,0>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>//the scene file:
>camera{
> look_at <0,-50,0>
>camera{
> look_at <0,75,0>
>light_source{
>sky_sphere {
> pigment {
> gradient y
> color_map{
> scale .4
> translate .7
>fog {
> distance 1000
>#declare Terrain=
>union{
>height_field{
> smooth on
> water_level 0
> finish{ambient .3}
>height_field{
> // smooth on
> water_level 0
> finish{ambient .3}
> translate<-1,0,0>
> png "HMap3.png"
> // smooth on
> water_level 0
> finish{ambient .3}
> translate<0,0,1>
> png "HMap4.png"
> // smooth on
> water_level 0
> finish{ambient .3}
> translate<-1,0,1>
>object{
> Terrain
> rotate<0,0,0>
Well, I'm hardly an expert, and in fact I had a problem with heightfields
recently, too. I tried turning double-illuminate on, and turning off
smooth, both of which are supposed to help the problem of artifacts in
heightfields, but it didn't work. That's why I'm using isosurfaces now.
Still, I can think of a couple things to try. First of all, a 500x500 source
image isn't very large, and you're scaling it by 1000. The mesh polygons
are going to be huge. I don't know enough to really challenge the comment
that smaller source files will get rid of that problem, however it seems to
me that if you have smaller polygons in the end result, then the artifacts
are going to be smaller and perhaps less noticeable. If you can get a much
larger image for the source, like 5000x5000 or something, I'd say to try
that out. You probably won't even need to turn on smooth with a source
image that large. The downside is it would probably take a lot longer to
render.
Well, let the experts give you the more believable advice.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Justin Smith" <t74### [at] yahoo com> wrote in message
news:web.3d9ceb442e983fbee07c96340@news.povray.org...
source
to
> render.
Yep, I sure hadn't seen it said anyplace that smaller files pieced together
might solve any problems with surface artifacts. Justin Smith certainly
points out the obvious, that larger files can produce finer details. Say,
Justin... if you could please remove some quoting in your replies that would
be nice :-)
I tried a 24bit color PNG image made from Adobe PS 5.0 LE and used as a HF
in place of Marcus'. It rendered very well using keyword smooth (on/off
isn't relevant nor possible) without artifacts or anything wrong except for
appearing somewhat blocky. With smooth commented out it was also okay, aside
from being completely faceted by the low resolution. Shadows looked okay,
colors looked okay. I didn't need to use double_illuminate but I did check
with and without it.
So I guess my question would be: what form of PNG is being used? Grayscale,
16bit or 24bit? Made with what program?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks for the replies!
I've tried using a large (5000x5000) pixel 24-bit .png, with and without
smooth and double-illuminate. Parsing takes forever when smooth, but the
artifacts seem to be gone! (or maybe they're just too tiny to see).
Thanks
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
